Question about JBL On Tour Computer Speakers
AGAIN ! Opening the JBL on tour ? :-(
Well, I (see here below http://www.fixya.com/support/t13963399-dismantle_jbl_tour m_pik) followed the instructions . Still I don't get it apart ? Is there anything else I have to do ? Thanks
  • 5 Answers
SOURCE: jbl wiring diagram
OK
See you CPU's backside  you will find  two different speaker input saket (in green ,yellow or pink) fix your speaker pins in their colors   and the speaker will work
Posted on Dec 22, 2007
NextStepComp
  • 185 Answers
SOURCE: JBL On Tour wont sound
Plug in another device and see if you can get sound. If you get sound from the other device, look at these tips for troubleshooting audio problems: http://windows.microsoft.com/en-us/windows-vista/Tips-for-fixing-common-sound-problems
Posted on Jan 01, 2010
SOURCE: JBL spot series speaker not working.
I know this is old but just incase anyone has the same problem. Its proabably the connection from back panel to the internal amp (Inside the sub enclosure). The ribbon cable has the + for the left speaker right at the edge with quite a bit of tension. Over time and with the vibrations from the sub this will bend/pull out slightly and needs to be pushed back on and some hot glue put around the connection to hold it in place.
Thats how I fixed mine anyway.
Posted on Feb 22, 2010
SOURCE: Just wondering what the power supply output JBL Media 3 Speakers
I have JBL Media 3 Speakers running on the factory supplied power supply and the label states: JBL POWER SUPPLY, Model No. DV-9319B, Input: 120VAC 60Hz 35W, Output: 13.8VDC 1.7A, UL Listed3T58, E148325, CSA LR99152, Power Connection Diagram shows, Ring: Negative, Tip: Positive, CAUTION: INDOOR USE ONLY
PERSONAL NOTE: The power supply DOES NOT have the AC plug on the back. It is big hefty black block with an attached AC cord on one side and an attached DC cord on the other. My speakers are mounted high on the wall and run at approx.90% of full volume with Bass & Treble set flat. Actual volume and EQ settings are controlled via the sound card software based "Mixer Panel".
Posted on Apr 15, 2010
SOURCE: buzzing sound coming from my jbl creature speakers no music
Hi I have had my JBL speakers for 2 years now. Recently the sub woofer has been making a buzzing sound but it continued to work ok. Now the speakers have also stopped working! Is there a solution to this problem? Would be grateful if someone got back to me.
Posted on Mar 10, 2011
I would like a full manual for the JBL xtreme speaker?
JBL Xtreme ' Splashproof Bluetooth Speaker with ... - JBL.com
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.7 - ‎35 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours playtime, dual USB port can link multiple speakers and ... Product Specs & Manuals.
JBL Xtreme ' Splashproof Bluetooth Speaker with Powerful ...
uk.jbl.com > Wireless > Portables
JBL
Rating: 4.8 - ‎36 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours ... http://uk.jbl.com/bluetooth-portables/XTREME.html? ... Product Specs & Manuals.
Jan 05, 2016 | JBL Audio Players & Recorders
Tell me how good of an amp this really is? Jbl grand touring gto1201.1model 2 not sure on the watts or class..
single channel about 1kW output power. About $250 when new.
Specs here
http://www.crutchfield.com/S-dVhyYWWFkBd/p_115GTO1201/JBL-Grand-Touring-Series-GTO1201-1-II.html
Aug 26, 2015 | JBL Car Audio & Video
How Dismantle jbl on tour
First you need to remove the sliding door. You can do this by opening it and lifitng one side with a screwdriver like on one of the pictures.
After that you can remove the battery cap and batteries.
Than you will need to remove the JBL logo. This is quite tricky. because it is glued.
After that you can remove all the torx screws and open the device.
http://imgur.com/a/Czyat
I damaged mine because I didn't have proper tools. Fixed the speaker though.
Aug 12, 2012 | JBL On Tour Computer Speakers
Blowing fuses and was told it's the power supply and is it worth fixing or could it be something else
That may be correct, the bridge rectifier diodes may have shorted out, it has shorted in the Output stage (The IC or the MOSFET's in the Class D amplifer which I think it is more likely to be the problem).
Not worth fixing, you may want to donate it to someone that is taking electronics class to learn how to troubleshoot the problem.
Same problem happens in JBL also. They do not make it to last anymore.
I had to modify my JBL sub-woofer due to shorted out Class D output module.
http://s807.photobucket.com/albums/yy352/budm/JBL/JBL%20PB-12%20mod/
Keep the links below if you have problem with TV's or monitors in the future.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Oct 13, 2011 | Harman Kardon HKTS 5 System
Hi I want to open the case of my JBL on Tour, but I dont know how to. I need to troubleshoot inside to fix this sound problem. Kindly help me.. Nikka
Its pretty late for your post....but today i repaired my jbl on tour...
there are 7 screws to be removed. 2 on thre front upper side, remove the battery cover an you find the first two. then remove the jbl sign, theres another under it. its very hard to remove, i had to destroy my jbl sign. now you have to clip out the cover when you have slided it back, under the back side who was covered, are the last 4 screws. now the nasty part is coming: you cant open it, cause its glued all around. put at first a knife into the slot betwen the upper cover & the under cover, move it around the jbl on tour, but watch out that you damage no electronic parts, or cut off the battery cabel (as i did ;) ) and now you can open the device. my jbl looks really bad after, but it works fine (had issues with the current cable)
Feb 28, 2011 | JBL On Tour Computer Speakers
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
Dec 18, 2010 | JBL CREATURE II Computer Speakers
Where do I put the battery"s? What goes into the portals on the inside? I can't find my user instrution's
There is 3 or 4 options for the on Tour speakers but not the model on your posting, I give you the link to the user manuals so you can compare them and get the appropriate I hope it helps.
http://www.jbl.com/EN-US/Products/Pages/SearchResults.aspx
if it takes you to the search box just type: on tour that should yield 5 results.
if it works for you don't forget to rate me
thx
May 21, 2010 | JBL On Tour¿ Portable Speaker System...
Jan 01, 2010 | JBL On Tour Computer Speakers
JBL On Tour Computer Speakers Logo
60 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
