Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
Problem for Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
Location of belt
By connorsgrann on Jan 10, 2009
can't find how to get to and replace belt on eureka whirwind model #4388
Best Solution
posted on Jan 27, 2009
Very Helpful)
lysager
Rank: Guru
Rating: 98%, 30 votes
There are two Phillips head screws on the cover over the power head. This is the cover that fits around the carpet height adjustment knob. You will notice there are four oval shaped holes on each side of the cover and the crews are in the ones closest to the vacuum handle. The screws are black and may be dust covered and therefore hard to see, but this is all that holds the cover on. When you take these out the cover will lift easily off. Once you do this the motor, belt, and brush assembly are accessible. I purchased a bag of two belts at the local ACE hardware. I recommend cleaning the brush while it is out. Also be sure the bearings on each end of the brush assembly turn freely as hair can work into these and cause them to bind. I hope this helps. lysager@gmail.com
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Eureka Whirlwind 4388 Bagless
Questions and Unsolved Problems for Eureka Whirlwind 4388 Bagless
Do you recommend Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum?
Answer
Answer
vacuume is spitting out dirt changed belt filter and checked tubes for clogs, Everything is fine
Answer
I was using the vacume and it just stoped   working like there was no power?
Answer
The rubber sponge like substance that helps seal the canister on the top is damaged. How do you get... (More)
Answer
MY 4388 WILL NOT PUT DIRT, DOG HAIR, ETC. INTO THE NON CONE SIDE LIKE IT ONCE DID, SEEMS CLOGED... (More)
Answer
how do i empty the cup ,it is bagless and i dont know how to pull it apart
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
