Question about Epson Workforce 1100 InkJet Plotter Printer
Epson workforce 1100 printer flashed lights then died
Had to take out printer head and all to clean, wouldn't allow ink to flow thru, put back together. When hooked back up to computer and turned on, it went thru motions, 2 lights came on amber, paper & ink. Flashed a few times and the printer still going thru it's motions of starting up, then all light went off and now nothing. Won't power on at all. DEAD! Have unplugged for 5 minutes to see if will help problem, tried holding buttons down to reset, but still nothing, can anyone advise???
  • Stephen Filyaw
    Stephen Filyaw Mar 07, 2014
    I have the same problem. It happened today. Any luck finding an answer?
3 Suggested Answers
websnail
  • 419 Answers
SOURCE: Epson R230 blinking 2 red lights after cleaning clog
I'll need a little clarification to diagnose this but my guess is that you have something blocking the path of the printhead.
There are two possible diagnoses...
1. Service error: This is when the waste ink pads are full.. It's indicated by both ink and paper lights alternating with each other. I doubt very much this is the problem...
2. General or "Fatal" error: This is when something stops the printhead from doing its job and usually follows something like a paper jam where something has been left behind or been pulled out of alignment when clearing the jam. I'm betting on this being the case.
Here's a few things to try.
  • Check to see if the printhead can move the full width of the printer. Note any areas it has problems reaching like the parking pad.
  • If you can identify an area that it's stopping at, note the direction of travel and see if there's anything in the way or out of place in that direction.
    - A common one is a bit of paper that's become covered in ink making it hard to see, sticking up and blocking the path.
    - Another is the parking pad or cleaning station being pulled out of position.
  • Check that all the rollers and paper guides are uniform and there's no obvious lifting. Sometimes they can be pulled out of alignment and just need nudge (carefully!) back into position.
Anything else is going to rely on you reporting back with a bit more information in detail as to where the printer is stopping, and any additional observations... The more you can provide, the easier it will be to solve the problem.
Regarding the solution from top_class... This would do more damage and solve none of your problem.. I suggest you ignore it.
Posted on Mar 16, 2009
  • 51 Answers
SOURCE: Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Posted on Sep 26, 2009
I have a epson workforce 7010, the black light will not go off. I tried different cartridge and tried cleaning the heads. what else may be wrong?
It could be possible that both of the cartridges you're using are empty. Also, Epson released a Firmware update on all workforce printers that really fix a lot of bugs that are with the systems. If you know they're both full, put the printer in the change in position (press ink button while printer is in standby with the power light steady) wipe the chip of the cartridge and blow on the metal connector inside the cartridge carriage. After doing all these processes close the door to the carriage, press the ink button and it should take right off.
Mar 23, 2013 | Epson WorkForce Office Equipment &...
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
Epson workforce 545 is printing & coping blank
Jan 18, 2013 | Office Equipment & Supplies
How do i remove printer heads
I did a search for what you wrote. Here are some links to check out:
http://answers.yahoo.com/question/index?qid=20071223181406AAHcNkz
I don't know if they'll solve your problem, but many times I find solutions this way...it is amazing what can be found on the internet!!
Sep 10, 2012 | Epson Workforce 610 All-In-One InkJet...
Epson Workforce 610 blocked (or malfunctioning) nozzles
With epsom ink jet printers the printhead is on the machine, not he cartridge as with many printers. This complicates things!
I suggest you get some cleaner cartridges put them in and run one single cleaning cycle each day until the cartridge is finished. Remember just One cleaning each day,,, this is to allow time for the cleaner to sit and "possibly" dissolve the blockage.
It is about your only chance of salvage.
An Ink jet printers worst enemy is sitting for long periods of time without printing on a regular basis, The ink dries in the print head nozzle!
Oct 17, 2017 | Epson Workforce 610 All-In-One InkJet...
Epson workforce 1100 flashing lights
please help me to find epson office me 1100 resseter
Jun 13, 2012 | Epson Workforce 1100 InkJet Plotter...
There is a red light on the inside of my Epson Workforce 610 that will not go out, I cannot print, and the software does not recognize my ink cartridges. (My ink levels are full). What is wrong?
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 23, 2011 | Epson Workforce 610 All-In-One InkJet...
Does hp have a cartage thats cleans printer heads
HP doesn't have a cartridge that cleans print heads. Normally you would do a light cleaning combined with a heavier cleaning. thru the software in windows. If that doesn't work then take out the cleaning head and soak it overnight in hot water. This will unclog the nozzles and once thats done, it will allow for the ink to flow thru properly. Put the Print Head back with the cartridges and run a few test pages so the ink goes back to flowing properly.
Apr 19, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I have 2 epson workforce 1100 there is error of mentenes tank i resive some resetter program but when i try it i resive cominication error eror code :2100012c how i can fixit
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 02, 2010 | Epson Stylus Pro 10000 InkJet Printer
Epson Workforce 1100 InkJet Plotter Printer Logo
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
