Question about APC Back-UPS ES 750 (BE750BBCN) UPS System
APC Back-UPS flashing red and green - APC Back-UPS ES 750 (BE750BBCN) UPS System
4 Suggested Answers
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
  • 28 Answers
SOURCE: APC Back-UPS ES 350 - when powered on has a
A blinking green light is likely an indication that the internal battery is nearing the end of its usable life cycle. If it's over 3 years old this is likely the case. To test, plug something in to the battery outlets and pull the plug of the UPS from the wall. If you get a short runtime (or none at all) it's the battery. Batteries are under $20 and can be found here: http://www.batteryinternational.com/apc-backups-es-be350u-ups-battery-ups-batteries-f1.html
Posted on Feb 12, 2010
  • 9 Answers
SOURCE: our ups apc back-ups 1500
remove the load fom the ups and restart the ups. if the ups alarms again then the problem is in the inverter.
Posted on Apr 19, 2011
Blinking red and green lights
Check battery and charging voltages. APC says 90% of faults are a dead battery. My experience also
Oct 15, 2014 | APC Products - APC - Back-UPS ES 750...
Apc smart ups 2200 all led flashing 3 orange 2 red 1green,what is that? and How to Fix It?
this problem is caused control board with that. the solution is replacement.
Jul 21, 2014 | APC Smart-UPS 2200VA LCD 230V...
Problem with a APC Back-UPS BR800I with AVR The
Hi Petkov,
It seems that Schneider / APC has a remedy for this on their forum:
http://forums.apc.com/message/35667
Reply or call if you need more assistance with this -- 407.380.9200
Oct 08, 2013 | Computers & Internet
Internal UPS fault. for br800i how to repair
Hi Edi, try to check the output relay of your UPS it might be stuck, thats always the case or sometimes the transformer.
Feb 16, 2013 | APC BR800I UPS System
What do the lights mean when it flashs green on 550VA battery back-up ?
This should help.
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=be550-fr&tab=documentation
Jul 24, 2011 | APC Back-UPS ES 550VA (731304248064) UPS...
Have brand new APC 900 UPS and when plugged in, both green & yellow indicator lights flash. Non-stop. Left unit plugged in for 18 hours (off) to charge battery as info sheet suggested, but lights still...
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Sep 19, 2009 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
My APC back-ups es500 is keep on flashing in orange and green having the beep sound, whe it is on. It has been used for nearly 3 years. What would be the problem...?
Probably the battery is drained. You should charge it first. And if the problem still persist, it could be that the UPS battery needs replacement.
Aug 01, 2009 | Computers & Internet
APC Back-UPS ES 750 (BE750BBCN) UPS System Logo
7,893 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
