Question about Sewing Machines
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
  • Sewing Machines Master
  • 1,564 Answers
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Posted on Nov 30, 2012
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
SOURCE: where are the oil holes
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
Posted on Feb 17, 2011
  • 632 Answers
SOURCE: PFAFF 1222E Sewing Machine (~1977). Mechanically Locked-up
You might be in "Stopmatic" mode. Check if your pressure lifter bar is in the upper most position, if it is the machine is disengage and you are set to wind your bobbin. Lower it to the 3 o-clock position this will engage the machine and the needle will operate.
Posted on Aug 10, 2009
  • 632 Answers
SOURCE: lost instruction manual
ebay
Posted on Jul 17, 2009
  • 255 Answers
SOURCE: I have a Pfaff 1222E sewing machine which needs a new motor
Good for you, to repair a great machine instead of buying some more modern, disposable machine!
I found a generic motor that will fit your machine at http://www.pfaffmachines.co.uk/partsDB/index.php?function=detail&recordID=185. Free delivery within the UK, but that doesn't help much, does it? There's several places in the U.S., like http://www.a1sewingmachine.com/parts.html http://www.sew4less.com/QuickSearch.php http://sewingpartsonline.com/
You'll probably need to look for a generic motor for your Pfaff, but they should be out there.
I did check eBay; they do have generic sewing machine motors, but unless you're very experienced with eBay, I'd be very careful there.
Check with your local sewing machine dealer/repair place (even if they don't carry Pfaffs). Maybe they can help.
Good luck--I wish I could be more helpful, but let me know if anything I've sent helps, ok?
Robbie
Posted on Jan 31, 2010
I have a pfaff 1222E machine and it is sewing very slowly, is there only one speed?
Most likely is is seized due to lack of regular oiling. If this is the case, AVOID trying to run the motor until the issue is addressed or the motor may be damaged.
Wheel on right side that controls the needle up and down is very tight...
Jul 15, 2017 | PfaFF Sewing Machines
I don't need help with a washing machine, it's a sewing machine!
Looks like an older mechanical machine--looks very similar to a Bernina I have. Hopefully nothing is broken or out of alignment that would cause this. Refrain from forcing the motor to run while the machine's parts will not move freely or it could damage the motor.
These are great machines, however, they do need maintenance to keep them operating smoothly. They are very prone to seizing when the old oil dries and turns to varnish, thus preventing the parts from moving efficiently. Here's the method I've use to fix several older machines that suffered from this problem. The problem can affect any moving part of your machine, ie the needle bar, the selector knobs/dials/levers, the feed dogs, the handwheel, etc.
Jul 13, 2017 | PfaFF Sewing Machines
Have needle heating the house of the bobbin case on pfaff 1222e
Rabi. Do you mean Hitting on the bobbin case/shuttle? That is a timing issue.
Nov 29, 2012 | Sewing Machines
Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
Jun 03, 2012 | PfaFF Sewing Machines
My Pfaff 1229 doesn't stop sewing when I let off the pedal??
it could be a short in the wiring, the foot pedal, do you have a manual
for the machine?
May 30, 2012 | PfaFF Sewing Machines
Pfaff 1222E machine not working right
Skipped stitches means a bent or dull needle or improper needle for the fabric being sewn. Try a new needle of the correct type for the material being sewn. If this doesnt correct it, then it will be a timing or needle to hook problem and should go to a qualifed dealer for repair.
May 06, 2010 | Sewing Machines
Can you get me a Pfaff 1222E motor please? Th
You will need a Pfaff dealer or go direct to the manufacturer or even go on ebay and try and purchase a similar model which may be cheaper thanh a new motor and you can then swap motor over.
Jan 31, 2010 | PfaFF Sewing Machines
Cannot turn the balance wheel - new machine to me. Pfaff 1222E
You have to lower the presser foot by one click to release it from bobbin winding mode. This mode is the same as needle down while presser foot is up so you can turn your work when it needs to go a different direction.
Nov 14, 2009 | PfaFF Sewing Machines
Aug 08, 2009 | PfaFF Sewing Machines
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Sewing Machines Logo
439 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
