Pioneer SD-643hd5 Rear Projection Yellow plume at bottom of set, and double images
  • johnjgreene Jan 10, 2009
    Did not fix the problem
  • johnjgreene Jan 17, 2009
    I'm at the step to replace the convergence IC. The replacement IC was purchased as instructed from your link, and was the one pictured in the instructions, which is part number STK-392-180. The IC that is on my set is part number STK392-110. Once again, my set is a Pioneer SD-643HD5(about 7 years old). Is it ok to use one with a different part number( STK392-180 instead of STK392-110)?
    Thanks!
  • 1,031 Answers
Your Convergence amp ic bad and need to be replaced.check out the image here http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm .hope this helps
Posted on Jan 10, 2009
    Sergeant:
    Novelist:
  • 326 Answers
Its the problem of ic on the main board and has to be replaced.
    Genius:
  • 1,550 Answers
Try hard reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
  • SAM ANDERSON Jan 10, 2009
    You need to replace the convergence IC in your tv .
    You can buy the STK from the link below
    STK ics
    For the procedure for fixing the convergence follow the link below
    Replace convergence ICs
    If you need further help feel free to ask .
    SAM ANDERSON
  • SAM ANDERSON Jan 19, 2009
    Sorry for late response .
    Yes you can use STK392-180 instead of 110 .
Pioneer SD-533HD5 53 in. Rear Projection HDTV Television - Need Manual ....
ManualsLib has the manual for the SD-533HD5 here: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html . (The manual covers two models.) Once you modify the picture parameters (starting from STD, REF THEATER, GAME), these are stored as the User mode. If you press Menu when done changing the parameters, that input should maintain the User settings for the last setting until you change the Picture type. If you modified the parameters for STD and then return to that input and change the Picture to GAME, any modifications to the GAME picture parameters will become the new User Mode. See page 50 of the manual for the details: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html?page=50#manual .
I hope this helps.
May 27, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tell me how to clean my bulbs and mirror of my pioneer SD-643HD5
You will have to remove the Front Screen ,First remove the bottom Panel and then the screen.
Jun 29, 2011 | Pioneer SD-643HD5 64" Rear Projection...
I have a Pioneer SD-643HD5 that was working and then just turned off? Now the tv won't turn on
CK for Blowed Fuse will be in middle of chassis 6amp fuse if it is blowed set will not come on.
Dec 30, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Just fixed the convergence chip problem.$534.00. Now 720p and 1080 1 signals are showing double images and colors. Also the componentinput #2 is showing double images on any format
many of these sets need the convergence adjusted in the 480 and the 1080 separate-- the set most likely if looks good in 480 needs to be adjusted with the original remote in the 1080 mode.
Whoever charged you 534 got you---if you did it yourself you paid way too much--with 1080 signal--enter convergence mode and try to adjust in customer menu--if 480 is ok---it needs to be adjusted in the hd mode.
SD TECH
Oct 31, 2009 | Pioneer SD-643HD5 64" Rear Projection...
My t v is begining to show with colors overlapping
Replace Both convergence ICs STK392-110s upgrade to the 180s MATS Electronics 1-800-628-1118.
Aug 08, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Where do i find convergence chips for a pioneer sd-643hd5
Complete convergence assy is available in Part Store for $126
Pioneer Parts has same CONVERGENCE ASSY for $288
Jan 25, 2009 | Pioneer SD-643HD5 64" Rear Projection...
HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
