Question about Watches
Replace wristband on Elgin II Model VC11-379
Wrist watch still under warranty but wrist band needs replacement. Purhased watch 5 years ago at Walmart
  • William J. Hopkins Nov 30, 2012
    The Elgin watch according to Walmart has a 10 year warranty. The wristband on the watch is deteriorating and causing skin irration. Would like to have the band replaced
  • 40 Answers
SOURCE: versace watch
call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website http://www.vertime.com
Posted on Feb 09, 2007
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
  • 9 Answers
SOURCE: watch band for shark freestyle model 788
You can call 888-222-5230 x502 Customer service. The band was $12 plus $3 shipping.
They will need your watch model. Shark Mako 788 (01)
Web site is www.freestyleusa.com
This is through Geneva Watch Group NY
Other post lists old extension (Linda works in another department now).
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
escapement
  • 2334 Answers
SOURCE: How do I adjust metal wrist band on Festina watch model
Check my tips here and find : How to remove or add links
Posted on Feb 06, 2010
Changing the wristband on Charge 2
What sort of wrist band do you have? Metal or leather/plastic? Make sure the spring pin is properly inserted into the holes on the watch. Sometimes if there is tension in the wrist band the spring pin will not expand all the way into the hole and thus will come out when putting the watch on the wrist.
Jan 10, 2018 | The Watches
I need a new band for my Elgin wrist watch. Fg8030. Cannot find anything on the web.
You can take your watch to your local Walmart and find a matching band and using the little like eye glass screw driver and remove the pins with out bending them and put a new band on
Dec 03, 2017 | Elgin Watches
I HAVE A NIKE WATCH WA0022 AND THE BAND IS BROKEN WHERE CAN I BY ONE
The model name is: Oregon Analog Chronograph
The band on this model is a pin-less design and the band cannot be replaced by the consumer. The watch may be sent to http://parsecent.com/ which is the authorized Nike watch service center and replaced for free if under warranty still (2 Years). They can also replace for a fee if outside of warranty. See here for information and tool purchase. http://www.easycarts.net/ecarts/ShoppingCart/Oregon_Series.html#WA0022
Apr 29, 2011 | Nike WA0022-002 Wrist Watch
Hi I have a quartz woman's watch that I bought at Big Lots store the other day.. the wristband is too big for me.. how do i shorthen it ? that band is metal...stretching whatever I call-- I need to remove...
Save your nerves and your money. Visit your nearest watch repair shop and ask to get links out. If you will try to do it yourself, you will loose your strap as you wont be able to put it back together. If you anyway decided to do it yourself, click on my profile and check out my solutions. I do explained all this tricky job to one customer about a year ago, so, you will definitely find it if you have enough patience to go through all my solutions. Rate me plz.
Mar 02, 2010 | Citizen Cortina Eco-Drive BM8194-50L Wrist...
I need the wristband from N13530
I NEED A WRISTBAND FOR A NAUTICA N13530
Dec 18, 2009 | Nautica N07518L Wrist Watch
Versace watch ( wristband)
Same place where you bought the watch, mate, same place where you bought the watch. Surely the watch is a Versage but the wrist band can be any band you can find at any good watchmaker of jeweller. ;)
Sep 23, 2009 | Versace 27473-008-00 Wrist Watch
Where can I get a wristband for Nautica 14504G?
CALLANEN INTERNATIONAL
ATTN: SERVICE CENTER
145 WOODWARD AVENUE
NORWALK, CT 06854
Phone: 1 800 248 3775 Fax: 1 203 855 0657
Nov 13, 2008 | Nautica N07518L Wrist Watch
Need a watch band for model 746 timex digital watch
I would suggest going to walmart or a jewelry store. Walmart has lots of different styles, materials, and sizes of watch bands. They will usually put the band on and fit it to your wrist size.
Aug 30, 2008 | Timex Watches
Band removal
There are two little pins on the strap. They need to be pushed to the side to release the strap
Dec 24, 2007 | Nike Triax 10 WR0006-001 Wrist Watch
Watches Logo
61 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
