Question about Motorola Mobility RAZR V3
Half of keypad not working
Left side of keypad doesn't work. I tried turning off, and back on, but no good. I tried taking sim card out, and back in, but no change. The main problem I now have is I cannot unlock my phone because the some of the pin # are keys that dont work. The phone wasn't dropped. Also I noticed that of the external buttons, on the left side the large button still works, but the small one below it doesn't - eg: I can see what ring setting I have, but I can't change it. Thanks
    Brigadier General:
  • 7,752 Answers
You need to have the mobile flexcable replaced in the phone.
Posted on Apr 15, 2008
How to fix my mottorola v3 its sayin no service???
Well it depends...First take a sim card beside yours, one you know works, power phone off, insert sim, power phone up, wait 1 minute, if it still says no service, power down and take the sim card back out, reinstall the battery and power phone back on without sim installed. when the phone powers back on does it say "no sim" or "no service"? this is to see if the phone can decipher a sim being in the phone and it not having service. If it say no sim then the sim reader is working, if it says no service then the phone may not in-fact be able to tell the difference of having a sim card and having service. Regardless at this point it is not working and more than likely an internal electrical component has failed and more than likely it may be the radio communication circuit of the device, if you insist on keeping this device- find one with a cracked screen but working internal and dissemble it, and replace the main board in the unit- this will in turn change the esn' imie, the overall serial of the phone, so take note of the new phone serial number- only replace the main bored under the keypad,be careful because it is VERY easy to mistakenly damage the device and its components. I do not see an easier way than this to fix you issue besides taking it in for repair- the new phone does not have to be broken but must be operational for making and taking calls. save all of your information as it will be lost after transfer-more or less still on the old phone, if this is an unlocked device please return original carrier sim for testing, and if the unit does not accept sim card skip those steps, and be sure that the new phone does not have an esn lock--Good Luck
Jan 27, 2013 | Motorola Mobility RAZR V3
MY MOTOROLA RAZR V3C SAID
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Aug 16, 2012 | Motorola Mobility RAZR V3
Sim card rejected to my nokia 2700classic cellular phone
Hi.Insert another sim card to your phone and try.if this doesn't solve , clean the sim card slot connector.Otherwise you need to contact a mobile technician.And if another sim card is working in your phone and your sim card shows Rejected to every phone,then the last solution is to change another sim card from the particular sim card provider.Good luck
Mar 02, 2012 | Nokia Classic 2700 Cell Phone
Left tail light only blinks with main light switch turned off. With main light switch on it doesn't work but front left turn signal works in both instances but fast with main switch on.
change the flasher unit, located behind the fuse panel on the drivers side foot kick panel , then check the bulb of the bad light, with a Meter,, you could have a bulb filament flopping around and it looks to be good , also check that the base of the bulb is clean and has good grounding
Jul 29, 2011 | 1999 Chevrolet S-10 Pickup
Nokia5310xpressmusic no network coverage
first check the Sim by keeping them in another Mobil if u get the the signal in the other then go in manual setting and select the consult network if your network is then also not detected then send it to warranty or replace the Antin wit the new one near a good Technision
Apr 22, 2011 | Nokia 5310 Cellular Phone
My LG VU is not reading my sim card but when i put Sim card in another phone is works
The sim card goes in the other way. The cut should be on the bottom left facing up. Try it and see if it works.
Jan 24, 2009 | LG Vu CU920 Cellular Phone
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Keypad doesn't work
good morning ! the problem of your 6233 nokia is keypad main brain or keypad crystal ic ,,,,try to clean the keypad mainbrain or replace the keypad ic ! thanks ! good luck ! ......
Sep 07, 2008 | Nokia 6233 Cellular Phone
My buttons on my cell phone...
Hi tina. Looks like the keypad of your phone is screwed. You will need to get a replacement keypad and it will be up and running again.Good luck!
May 23, 2008 | Motorola Mobility RAZR V3
No response from keypad input?
check your volume keys or any side keys that get stuck... or if you can open your fone check its keypad for any shortage...
Oct 26, 2007 | Samsung SGH-d407 Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
