Question about Black & Decker Mouse Sander/Polisher
My Mouse sander still turns on it just does not sand
I can turn it on, but the base doesn't vibrate so I can sand anything.
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: My Black & Decker mouse is now making a louder
possibly a bearing is seizing up causing the motor to slow down and therefore less vibration. You can try Dewaltservicenet.com for a breakdown or to find a repair center.
Posted on Jul 22, 2010
  • 4 Answers
SOURCE: I have a mouse sander
Get Free online manuals here http://www.blackanddecker.com/CustomerCenter/Manuals.aspx
Posted on Aug 18, 2010
domotek
  • 591 Answers
SOURCE: can't figure out how to
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
Posted on Aug 06, 2011
  • 25 Answers
SOURCE: I sanded with my B&D Mouse Sander for an hour
I have had two Black & Decker mouse sanders. The first one died on mie after a respectable time so I decided to buy a new one (they're relatively cheap)
Now my second Mouse is also starting to rattle, just like the first one. So I took it apart and I now know some weak points of this machine:
1. The motor is a small one and does not really cool itself that good. After sanding for an hour, the poorly designed plastic fan at the bottom will deform because of the heat which causes more problems.
2. the bottom of the mouse is attached to the body by three 'hinges'. I know you;re not supposed to, but when you're sanding for an hour, you start to press the Mouse a bit more because you want some @#$ progress on your sanding work. This causes the hinges to loosen up. This is actually the ratttling sound you hear when you're mouse starts giving up.
So why has the Mouse gotten it's longest period after the rattling starts? Because of this the alignment of the mouse's sanding foot is not 100%. This means: Extra friction, extra heat: engine dies.
You can prolong the life a bit though:
When the rattling starts:
Take it apart and fill up the rear hinges by adding material on top of the hinge so the foot is aligned again. The Mouse sounds a lot better I can tell you. For me this meant a mm of metal on top of the rear hinges.
When you have it apart: clean the Mouse, get rid of the dust. The machine is very simple. You just need to loosen four screws and have a brush + vacuum cleaner ready.
good luck!
Grit
Posted on Jul 11, 2012
Palm sander not vibrating
Only real way to find out what is wrong is to open it up on this one. They are mostly plastic parts and you will probably find the broken part or where a gear is worn out.
Jul 04, 2016 | Ryobi Tools & Hardware - Others
Base has come loose on one side exposing a small white plastic foot and is making a louder noise when turned on. Is there any way I can tighten it up?
I don't have a solution yet, but the probable cause of the noise and vibration is that the white rubber post that suports the sanding plate is broken. To get it out means totally dismantling the sander (gives you a chance to clean it out as well) to get the offending post(s) out. Two are broken on mine, the back two.
The next problem is to find a supplier of these posts as they are not on the spare parts list from B&D, and so far I have found no other supplier.
Come on B&D, this is a wear part. Add it to the current restricted list of spares.
Apr 02, 2013 | Black & Decker Mouse Sander/Polisher
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
Can't figure out how to load the sand paper on to the mouse sander
Cheers!
Aug 06, 2011 | Black & Decker Mouse Sander/Polisher
How does the sand paper attach to the removeable bases? There is a screw that keeps the base on. Nothing is sticky to hold it there? The piece that is like velcro is great but it somehow needs to be...
the velcro piece should have a removeable or i should say a peel off paper like a sticker and then stick the velcro to the base off sander if it was not on when you got it. it was not put on at the factory cause they give you the option of using stick on sheat of sandpaper or hook & loop (velcro).
Apr 07, 2011 | Black & Decker Mouse Sander/Polisher
I have a Dewalt sander I am using for wet sanding on a boat hull. I have already burned one sander out do to moisture I figure is there a way to protect the new sander from this happening again I am...
Impossible not to get water in the bearings and motor. It is vibrating too fast. You need air sander. Or sand dry, then wet sand the primer by hand.
Dec 17, 2010 | Dewalt DW421 5'' orbital sander
My Black & Decker mouse is now making a louder than usual noise and the base does not vibrate as it used to. What could be wrong?
May 08, 2010 | Black & Decker Mouse Sander/Polisher
Hand sander stops spinning once placed on item to be sanded
This sander has a brake pad that is supposed to stop the rotation when the sander is not actually in use. It sounds like it's malfunctioning.
The only other thing I can think could be a cause of what you describe is an improperly assembled sanding base. Have you changed out the base, and if so, were you sure to properly align the replaced base on the machine before you tightened the allen screw?
If you're not comfortable disassembling a tool that is still under warranty ( I think it's two years for that one), I would recommend finding a Dewalt service center and taking it in for a factory service call.
Mar 24, 2009 | Black & Decker Black And Decker Cyclone 4...
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
Black & Decker Mouse Sander/Polisher  Logo
41 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Rabbit Brains
Rabbit Brains
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
