Question about Edirol Computers & Internet
Driver ua 25 ex
I'm running windows vista 32 bit the installation works untill the pc asks to me to plug in the interface. after i plugged it, ask for me to locate drivers in my system. after this step i recognise where the driver is, which is on my hard driver and C and after i download the driver , my system gives me a prompt to insert cd, i do not have the cd, the driver is on my hard drive , i also have the driver on an external hard drive, so i send a command to my system to locate the driver(downloaded from the website), and this does not work, how do i get this to work, what is the work around for getting my system working with this problem?
    Sergeant:
  • 150 Answers
Vista is dead, and good riddance. If you want a safe, free, modern operating system, download a nice distro of Linux like Ubuntu, Mint, ZorinOS, Elementary, Solus. Try it on a flash drive or DVD. If you have an old machine, try Lubuntu 32 bit, Puppy or Bodhi. Welcome to the new century.
Posted on Apr 08, 2017
3 Suggested Answers
SOURCE: i am running windows 7
Haven't tried it (us-122 + win7 x64) but you could turning off 'forced driver signing'. http://www.tipandtrick.net/2008/permanently-turn-off-and-disable-64-bit-x64-windows-vista-forced-driver-signature-signing-with-readydriver-plus/
Win7 32bit doesn't have this feature, only win7 64.
Posted on Oct 18, 2010
guyhammerton
Hey All,
The best way to get the US-122 working on Win7 is to;
-Download latest drivers for US-122 from Tascam site
-This will be a Vista 32 or 64 bit, what ever Win7 you run
-Right click the exe file, go to properties, in the compatibility tab, set compatibility mode to run as Vista SP2 version.
-Install
-Then check drivers, firmware updates
-Ensure US-122 not using MS Wavetable GS Synth.
-Set to use Asio drivers
-Check latency settings of US-122, by going to windows control panel and searching for Tascam
-Check latency settings in asio drivers, and untick 'Allow application to take over this device' or whatever it is, this should also disable MS Wavetable GS when US-122 and asio in use in use
-Around the 512 samples should get no clipping/popping, with below 10ms latency for most asio drivers, which is as good as the US gets
-Some asio drivers (Full duplex etc) will give you a false latency figure in Cubase etc, but I have found no clipping/popping or latency with US-122 set to 512 and asio driver set to mid range (around 50ms) on i7 2-3ghz, 8g ram....
See my new label/production company at:
www.thefunkcontraption.com
Posted on Jun 15, 2012
Ua 101 driver won't install on windows 7 64 bit
Officially Microsoft says that 32bit drivers are not supported on a 64bit system. Check hardware manufacture for updated drivers. Good luck.
Aug 31, 2012 | Edirol UA-101 External Sound System
Can get signal from UA-25 to computer... but no audio from computer to UA-25?
Here is one solution uninstall the default driver or roll back driver. Restart your computer. When you get into windows wait for everything to load and then plug in your audio device. If you have it plugged in when windows starts then it will install a driver. In automatic updates you can select to notify of updates, but lets you install the ones you want.
Thanks for using Fixya
SAM ANDERSON
Sep 29, 2008 | Edirol UA-25 External Sound System
My webcam microsoft vx-500 is not working..what will i do to use this webcam ??
You can download the drivers for the webcam from the links mentioned below
Windows XP (32 Bit) LifeCam 3.5 32-bit for Windows XP SP2 or higher (excluding 64-bit)
Windows XP (64 Bit)
LifeCam 2.04 for Windows XP 64-bit
Windows Vista (32 & 64 Bit) LifeCam 3.5 32-bit and 64-bit for Windows Vista
Windows 7 (32 & 64 Bit) LifeCam 3.5 32-bit and 64-bit for Windows 7
Simply download the driver and run the setup it will install your camera, if it does not detect the camera , disconnect the camera and plug in again and it will load the drivers
If you require more assistance regarding this, feel free to contact
regards, BA
Jan 13, 2011 | Microsoft LifeCam VX-1000 Webcam
Why can't I load my NYKO software on my pc/Vista
http://rapidshare.com/files/362751095/Nyko_Airflo_Drivers_2.0.0_For_Mac_and_WinXP.zip
Here are the most up to date drivers. If still problems, install in compatibility mode. These do work on vista 32 bit as I have used them before
May 08, 2010 | Nyko Airflow EX PC Game Controller...
Drivers not working on PC run on 64 bit
Plz
Stape::1
Desktop Right Click ---- Property
Setting Tab
Chang Your Screen Resolution 1024*650 32 Bit
Try Again
Driver Install Successfully .........
Aug 17, 2009 | Edirol UA-25 External Sound System
My Epson RX 620 will not print anything from the computer with Vista
Have you tried running a print test page? Have you gone to epson.com website to see if they have printer driver available for your printer...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads -
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Edirol UA-1EX - hearing noise on audio playback
No solution, but I had the same issue with my old laptop, I tried everything, the only thing that worked, was to use a voltage generator, set it to 19.5 V (this was what my laptop was converting to) and getting a laptop power plug and creating a connection. Because the power pack is a SMPS, it was very noisy and this noise would be transferred to the recording.
Question of my own, where did you find drivers for Windows Vista 32 bit? I can only get my UA-1EX to run as speakers, not a recording device!!! HELP!
Submeg
Dec 10, 2008 | Edirol UA-1EX Sound Card
Edirol ua-25 not detecting midi but audio works fine
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Feb 27, 2008 | Edirol UA-25 External Sound System
Computers & Internet Logo
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
