Question about Akai Mpk49 Mpk 49 Midi USB Keyboard With Mpc Pads New
How to fix mpk 49 usb entry
Where i plug my cord into the back is loose
Some keys on mpk49 do not play unless hit hard
sounds like dust, if you know some one with an air compresser ask them to give it a blow through, if not then it is down to caned compressed air, if that is not enough, you need to open it, and clean the contacts (DVD cleaner is cheap and good)
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
How to fix loose USB on M-Audio Keyboard
Uscrew the case, desolder the USB socket from the circuit board. Buy a identical spare from any electronic shop using the broken one as sample. Solder in new USB socket.
USB sockets has only 4 connections - easy job.
Jul 30, 2014 | M-Audio Axiom 49 MIDI controller keyboard
How to fix loose usb on Axiom 49 keyboard
Wow...just loose or intermittent as well? Most of these jacks and connectors are directly soldered to the main circuit boards which could mean broken and/or intermittent connection. Check your warranty status but if expired...to resolder check for a local electronics repair shop to help as the disassembly and intricate work may be beyond many DIY fans.
Jul 30, 2014 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
Akai mpk broken conector
Its a lot simplifier than that really.. all you need to do is unsolder the old one and re-solder the new one.. The pins and connectors are standard.
Dec 30, 2012 | Akai MPK mini MIDI Controller Keyboard,...
How do i fix the usb port on oxygen 49 it seems to be loose . the keyboard powers on but is not being recognized.
The usual problem of these not being recognized is improper installaation or missing the driver software in the computer. The jacks sometimes appear loose but that can be normal. If you wiggle the jack and there is marginal connections, usually the computer will respond with the USB found and the disconnect tones. If the USB cable has been yanked, then solder could have been broken at the connector. Opening these units one has to be very careful to not damage the cables between the halves of the shell... also keeping track of the screws and type is a must.
Sep 07, 2011 | M-Audio Oxygen 49 USB Midi Controller
Hello, one of the keys has come loose in courier transit and i cannot seem to fix it back
To repair a key that has come loose from the pivot, on MUST open the keyboard to get at the mechanism of the leyboard itself. Usually a spring has been displaced or, worse case, a piece of the key pivot is broken off. Be real careful of the ribbon cable tying the two halves of the shell together. Keep track of the screws, type and length to restore them to the proper places.
Sep 04, 2011 | Novation 49 SL MkII 49 note USB MIDI...
So, I have a controller keyboard, the MPK 49 that will not turn on via usb. the Display on the keyboard seems like it kinda gets power, but is not backlit at all.
The controller will not power from the USB. You MUST use a power adapter. The display takes far more energy than can be had from a USB port.
Dec 29, 2010 | Music
Operational book for a akai pro mpk 49
Try this website:http://www.akaipro.com/content1023 I hope this helps.
Apr 07, 2010 | Music
My keys have popped up on my akai mpk 49
use black electrical tape. put tape on the edge of the key and cut it at the bottom of the mpk
Feb 21, 2010 | Music
Akai Mpk49 Mpk 49 Midi USB Keyboard With Mpc Pads New Logo
Top Akai Music Experts
T-Comtech Repairs
T-Comtech Repairs
ray gallant
Are you an Akai Music Expert? Answer questions, earn points and help others
