How do i remove the inner tub hub on a GE Harmony washer (WPGT9350C0) I have the tub nut off but there doesn't appear that anything is holding the inner tub hub (WH45X10055)
Lumpy816
  • 246 Answers
SOURCE: Kenmore top loading washer model 110-9259220 90 series has a very slow leak
Once you have the console open and the cabinet removed, take off your tub ring (the white plastic cover over basket) and you agitator. Unfortuneately, you're right there is a special tool for removing the 4 notched nut. I would check with my local appliance part store or order it from the manufactures web site. I belive they call it a spanner wrench. After that, your basket will lift out.
Posted on Jun 16, 2008
MNTECH
  • 1543 Answers
SOURCE: GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Posted on Jun 12, 2009
  • 70 Answers
SOURCE: AFTER REMOVING THE INNER TUB NUT HOW DO YOU REMOVE
Are you talking about the wash basket?
Posted on Jul 10, 2009
  • 850 Answers
SOURCE: Inner tub broke away from outer tub casing
yes its fixable but labour costs are high & its not a quick repair job!
go get a new one!
less stress no waiting!
Cheers Rob
Posted on Jul 21, 2009
  • 152 Answers
SOURCE: I cannot remove the hub nut on my GE Profile
1st DO NOT try to cut the hub nut off. This is a left hand thread so it has to be loosened by turning clockwise. There are two ways to remove this the hardest is with the removal tool WX5X1325 and a hammer or sledge. The second way is much easier use a 1 11/16" socket with a impact drill.
Posted on Feb 28, 2010
How do you get the inner tub hub only, for GE top load washer?
You can go online to searspartsdirect.com and enter your model #. You should be able to find part description, price and part #. Google part #. Should be able to find pretty cheap
Feb 24, 2015 | GE Washing Machines
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
My Amana NAV2330AWW (S/N12279742EP) has been in service for six years. It has begun making a loud squealing, friction-like noise at the spin cycle. I removed the agitator assembly after being told it...
Firstly i want to apoligize for the quesionable advice,some on here or elsewhere on the net fixed their washer and suddenly their are experts!!
Now Then as you know your washer is made by Amana/Speed Queen and has no agitator dogs(a quick search of parts breakdown will show anybody that) it also has no spin tube (aka basket drive),the brake pads which it does have would squeal only when washer stops spinning if they were bad just like squalling brakes on or vehicle the are quite till applied if bad,what the most likely cause of the noise is going to be the tub bearing,it is on the bottom of the outer tub. The inner and outer tub must be removed,it is advisable if replacing the tub bearing that you also replace the tub seal since it may not seal correctly once taken apart and leak badly.The hub taht connect inner tub to transmission must be removed so ya can remove the outer tub it requires a special wrench which is not to expensive but nothing else will work. IF ya want to go ahead and repair this the part numbers are;
TUB BEARING 40004201P
TUB SEAL 35-5655-1
SPANNER WRENCH 306P4
PROCESS TO REPLACE BEARING;
unplug power
remove front panels
remove screws holding top to cabinet
remove plastic tub cover by down slightly and lift tabs
remove agitator
remove bolts from hub under agitator and remove inner tub
use that spanner wrench and a hammer on nut on hub and remove nut in counterclockwise direction by hitting wrench w/hammer
lift off hub
remove rubber tub seal
remove all springs from outer tub by locking on vise grips and pull springs off
remove bolts holding outer tub to the to tub support
pull off outer tub and set down so bottom is facing up
remove old bearing and install new old
reassamble in reverse order
this is a link for parts breakdown http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Washer-Parts/Model-NAV2330AWW/1268/0153200?pathTaken=&prst=0&shdMod=NAV2330AWW
to order parts order from sears or for a cheaper price by a little rearsch from
apdepot.com
assuredparts.com
appliancepartspros.com
repairclinic.com
Good luck, if you have any question reply and ask away.
Gene
Aug 07, 2011 | Amana NAV2330AW Top Load Washer
I have a 1960s whirlpool washer that is leaking out of the bleach line. I was trying to figure out how to pull the drum out of the barrel.
At this point in time it might be less distructive to go shopping for a new machine. To remove the inner basket you will have to remove the tub cover which will probably not seal after removal due to errosion of the tub. With the tub cover removed, remove the agitator which will uncover the next great feat, the hub nut which requires a special wrench to remove. If you can remove the hub nut after 40 years of corrosive detergent water you may be able to remove the inner basket if it isn't ceased on the drive block.
Feb 27, 2010 | Washing Machines
Where is the windshield wiper motor on a 2007 Dodge Caravan and how do I replace it?
Wiper Motor: Service and Repair
Removal
REMOVAL
The front wiper motor comes as a unit with a wiper pivot on each end and mounts to a shaft that holds these two inner pivots.
1. Disconnect and isolate the battery negative cable.
2. Remove the wiper arms.
3. Disconnect the washer hose at the in-line connector located near the air cleaner housing.
4. Lift the cowl grille and disconnect the washer hose grommet from the hole in the wiper module. Pull the washer hose and the grommet
completely through the wiper module tub hole.
5. Remove the cowl grille.
CAUTION: Be careful not to scratch the cowl grille on the corner of the hood.
6. Remove the four brace nuts holding the wiper tub to the lower windshield fence.
7. Remove the four bolts underneath the wiper tub inner brace holding the tub to the bulkhead.
8. Remove all four inner support brace mounting nuts and pull the inner braces just free of the mounting studs.
NOTE: The wiper tub will drop down slightly.
9. Disconnect the driver and passenger side wiper link ends at the inner pivots.
10. Remove the two left wiper motor assembly mounting nuts.
11. Remove the two right wiper motor assembly mounting nuts.
12. Partially lift out the wiper motor assembly out of the wiper tub.
13. Disconnect the wiper motor electrical connector.
14. Remove the wiper motor assembly the rest of the way from the wiper tub and remove from vehicle.
Installation
INSTALLATION
1. Install front wiper motor assembly onto wiper tub.
2. Connect the electrical connector to the front wiper motor assembly.
3. Install the four mounting nuts. Tighten nuts to 9 Nm (80 in.lbs.).
4. Push the four inner support braces onto the studs and install the four nuts. Tighten the nuts to 9 Nm (80 in.lbs.).
5. Install the four bolts underneath the wiper tub inner braces that hold the wiper tub to the bulkhead. Tighten the bolts to 17 Nm (150 in.lbs.).
6. Install the four nuts holding the wiper tub to the lower windshield fence line. Tighten nuts to 7 Nm (65 in.lbs.).
7. Apply grease to drive link bushings.
NOTE: Make sure to use Mopar(R) approved grease.
8. Attach the driver and passenger side outer wiper linkage to the inner pivots on the front motor assembly and firmly snap into place.
CAUTION: Do not apply too much force to engage link bushing or damage can occur to the drive link bushing.
9. Position the cowl grille in place.
10. Install the washer hose and grommet into the wiper tub.
NOTE: Be sure to properly seat the washer hose grommet into the bottom of the wiper tub.
11. Connect the washer hose at the in-line connector located by the air cleaner housing.
12. Install the cowl grille.
13. Connect the battery negative cable.
14. Verify that the wiper motor is in the Park position by cycling the wipers system. When done, remove keys from ignition.
15. Install the wiper arms.
16. Align the wiper arms and tighten nuts to 35 Nm (25 ft.lbs.).
17. Install the wiper arm nut caps.
Sep 13, 2009 | 2007 Dodge Caravan SXT Minivan New Cars
Washer has a very musty smell. Trying to raise the top to clean inner tank but it will not budge. Does the top raise on the WJSR2070B model. Do not want to break it
Yes, but I would advise to try a washer cleaner before going through all the work to dissassemble your machine.
Use the longest, hottest cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer.
You could check out http://www.smellywasher.com/ for one possiblity. Others are " Washer Magic " or these: 73b1c2a.jpg fb3071a.jpg
If you still want to tackel the dissassembly: The washer front comes off by using a putty knife to push in the two retaining clips on the very top edge, where it meets the washer top. Now you will be able to access the screws which hold the top down. Of course to remove the inner tub, you still have to remove the lid switch, the agitator, agitator drive, the left hand threaded nut below that, the wire connection to the motor, the four tub retaining straps, the tub to pump hose, the four suspension rods, the tub cover and the water level hose. Then you would be able to remove the inner tub and pressure wash out the outside of the inner tub and the inside of the outer tub, if you bring the tub assemble outside. TRY THE CLEANER FIRST !!!!
Aug 16, 2009 | GE WBSR3140DW Top Load Washer
Jun 11, 2009 | GE WDSR2080D Top Load Washer
Maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Jul 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loose noisey tub
This is probably a normal GE washer tub issue. Problem is, you have to remove the inner drum to repair it. Before we go through all the instructions, let me know if you want to take this on yourself. Will need a good sized tool chest to do the job (1/4" and 5/16" nut drivers, screwdrivers, hammer, good sized pipe wrench, torks bits, etc). Let me know and we can go from there.
Jan 24, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
