Question about KitchenAid KGST307 Gas Kitchen Range
New Kitchenaid stove used 1st time turned oven off now beeping
This is a first use problem I hope...I turned it off and it started beeping; constant beeping...please help!
  • Anonymous Jan 18, 2009
    WE JUST PURCHASED A NEW GAS KITCHENAID STOVE AND ALL THE BUTTONS WHEN PRESSED ONLY BEEP?
    SUSPECT MAYBE IN SABBATH MODE?
    BUT DO NOT NOT KNOW HOW TO OVERIDE?
Hello! Yes, I did figure out the beeping...while on a long hold with the kitchenaid helpline, I took the "cookie sheets off of the top of the stove" and voila the beeping stopped. Simple, but who knew? I hope this helps someone else.
Posted on Jan 11, 2009
My beep quit! Beep used to work when the oven came up to temp, the timer timed out, or a button was touched. Can it be reset or will I need to replace it? Where's the control board located and how do I...
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
Oct 23, 2010 | KitchenAid KGRT607 Gas Kitchen Range
My kitchenaid 30" built in microwave/convection oven beeps all the time. I have to turn the power off to stop the beeping. when i turn the power on the beepeing starts. I am able to use the microwave...
Well is there any error code on the digital display of your Microwave/oven?
Do you mean how to keep it from beeping when you press keys, or is it beeping by itself?
If the microwave oven is coming on or doing anything (beeping) by itself, this is very dangerous and can result in a fire.
First of all you cam leave it unplug for half hour, it helps you to reset your microwave/oven. If further you have the same problem please reply to the questions.......
Good Luck!!
Thanks
Jul 27, 2010 | KitchenAid Architect Series KBHC109JSS...
KitchenAid KEDT105V Electric Stove - f-5 beep Started beeping out of the blue, pushed cancel and it stops for 20 seconds then continuous beeping. If the oven is on the beeping will stop. Hope you can help,...
Hi, F5 means your control board may have suffered a fatal error. Unplug the unit for 30 seconds, when the power is re-applied if the error comes back you will need to replace the control board (ERC). Mike
F5 Board failure Replace control board (also called ERC or clock).
Mar 25, 2010 | KitchenAid KESC307 Electric Kitchen Range
Temperature probe guide won't quit beeping
you have a bad computer board or clock assy. same thing the most common thing that cooks the board is heat and usually from self cleaning the oven,next time send the model number,if this is a slide in stove under the oven door is a drawer,open it and look at the frame,you'll see a tag with model and serial numbers,if that functions by itself you have a bad board.
Feb 07, 2018 | KitchenAid Ovens
When i turn on a element the broiler comes on
Your electronic control is bad. Your clock needs replacing.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Off button doesen't shut off oven
You will probably have to replace the electronic range control.
Jan 03, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Jul 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Kitchen Aid KESC300 smooth top electric stove
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Sep 30, 2007 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
746 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
