Question about Vacuums
Rainbow vaccum- power nozzle will suction up but will just spit it all out just a few seconds later. Everything is rotating fine and can't seem to figure out why...any ideas?
  • Vacuums Master
  • 18,391 Answers
Click this link and there are videos that willhelp you unblock your machine
http://rainbowsystem.com/support/videos/
Posted on Nov 28, 2012
reddevil6
  • 1673 Answers
SOURCE: Rainbow SE power nozzle
If the brush is spinning ok, and the belt isn't slipping, then probably the circuit breaker is bad, or the motor is causing the problem.
Posted on Jan 09, 2008
  • 11 Answers
SOURCE: No spinning in the power head
First, check the red reset button on the power nozzle head. - if it's popped out, push it in. Also, if you have a switch on the handle, make sure you're pressing it while you're vacuuming. if those obvious solutions are already remedied, you may need to check the power outlet on the canister for voltage with a voltmeter while the vacuum is running, and then check your power hose and wand for continuity (checking for a broken wire) while the hose is disconnected from the canister. If all this checks out and the power nozzle still doesn't power on, you may have a bad motor in the power nozzle. If you're good at taking things apart, then it's a simple fix to replace the power nozzle motor.
Posted on Jul 03, 2009
  • 14 Answers
SOURCE: weak suction on rainbow se vacuum
With years of use, you will collect a layer of "micro dust" on the impeller (the fan part) which reduces the efficiency. A toothbrush and some mild cleaner with gently scrubbing will restore it's power.
The impeller is that parts that spins that you can see when you take the top off to fill the water tank.
Hope this is the answer that you need!
Posted on Nov 15, 2009
VacuumRepair
  • 438 Answers
SOURCE: My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Posted on Apr 11, 2010
SOURCE: no suction power ,brush wont spin on carpet power nozzle. When it
You need to replace the belt that turns the brush.
Posted on Jul 03, 2010
Upon turning on vaccum it starts ok, but a second later it spits out some dust dirt out and does not vaccum. We hear like a poof suction when this happens. Cleaned all the tubes around it, but thinking...
The poof suction sound you hear is most likely the suction release valve opening up because there is a clog or restriction somewhere. If you don't feel qualified it is usually a better idea to take it to a qualified repair facility.
Oct 26, 2013 | Panasonic Bagless Upright Vacuum Cleaner ...
My rainboe has no suction
<p>The hose could be clogged. <a href="http://www.rainvac.com/rainbow-vacuum-schematics"></a>Check the suction on the main unit without any hoses connected. If that seems good, then connect a hose and check suction again at the end of hose. If suction is still good and you are having issues when using the power nozzle, then open up the bottom of the power nozzle to check for clog.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
Apr 01, 2013 | Rainbow E series Canister Wet/Dry Vacuum
I have a model DC3 rainbow thar has lost suction. what can i do to fix it
Check suction at intake without any hose connected. If that is good, then connect hose and check suction again. If that is poor, then you have a clog. If still good, then check power nozzle by getting into the belt area.
RainVac
www.rainvac.com
800-523-0510
How do I get the motor out of the power nozzle on the E-series?
The eSERIES Rainbow has several versions of the power nozzle. Some screw apart and others have snap connections. Look at our website on the manuals page to determine your model. You can also call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Jun 02, 2012 | Rainbow E series Canister Wet/Dry Vacuum
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vaccum roller got caught in bed spread and stopped rotat
Assuming the belt is not loose, it sounds like something is still stuck under the roller (part of the bed spread?)
Did you check the power nozzle circuit breaker?
You may also need a new roller brush
Mar 17, 2010 | Rainbow Technologies D4 Bagless Vacuum
Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Feb 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Weak suction on rainbow se vacuum
Check for clogs in the nozzle air passages (remove bottom plate)
Check for clogs in the wand
Check for clogs in the hose (trow in a pebble or a penny and see if it comes out the other end)
Make sure separator is clean.
Remove exhaust cap (sometimes there is a sponge in the cap that gets disty and does not let the air pass through).Have in mind that it will not pick up well if the suction and the belt is good but brush roll bristles are worn and too short.
Good Luck,
Rocky
Dec 21, 2008 | Rainbow 75th Anniversary Canister Vacuum
Oct 23, 2007 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
