Question about NorStar M7208 Corded Phone
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
    Scholar:
  • NorStar Expert
  • 277 Answers
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Posted on Nov 28, 2012
Testimonial: "This is exactly what I needed. Thank you so much."
SOURCE: caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Posted on Sep 21, 2008
ynotphone
  • 192 Answers
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Posted on Mar 25, 2009
ynotphone
  • 192 Answers
SOURCE: How do you page with a Meridian Norstar M7208
There is another page, acting more like a directed intercom page...
If you want to talk to someone and you know where they are (general area) you can do a FEATURE 6 6 and the extension number.
This is a direct page and when you page this way, that person can respond back and you can hear them.
Posted on May 02, 2009
SOURCE: Doesnt ring
My BT Meridian compact does not ring after it powered down in a thunder storm. The lines flash and can be answered as normal just no ringing sound
Posted on Jun 16, 2009
  • 4 Answers
SOURCE: How do you set up caller ID on a Norstar M7208
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
Posted on Jul 30, 2009
What could cause norstar m7208 phone to not receive incoming calls
If you have lines appearing on your phone and they don't ring you need to program lines to ring. This type of programming is done from a M7310 phone. Page 323 of this manual shows how to program this on a NorthStar MICS Ver 6 phone system.
http://pdf.textfiles.com/manuals/TELECOM-F-R/Nortel%20MICS%20System%20Installer%20Guide%206.1.pdf
Enter the programming mode : Feature **266344
Password:266344
You will have 4 programming buttons on your phone, normally the 2 top left and 2 top right of the 2 vertical rows.
top left = move up one level
lower left = back
top right = select
lower right = next
once you enter the programming mode press next to "Terminals and Sets"
press select
enter your extension number
press select
press next to "Line Access"
press select
press next to "Line Assignment"
press select
use the next key to go to the line you want and use the soft-key below the display to change it from "Appear" to "Appear and Ring"
May 05, 2015 | Nortel Norstar M7208 Telephone
Norstsar M7208 Corded phone cannot use handsfree feature
Your problem is in the phone system programming. I would need to know how old your main cabinet is in order to tell you how to fix it. On most Nortel systems you use "Feature Key" **266344 (Feature **CONFIG) . You will need to program from a M7310 phone because you need the 3 soft keys under the display which the M7208 does not have. The top 4 keys on the phone are used for programming (2 LEFT & 2 RIGHT) . I'm referring to the 2 vertical rows of keys (5 LEFT & 5 RIGHT). Upper left key is up a menu, upper right key is SELECT, lower left is BACK, and the lower right is NEXT. I believe you need to find the CAPABILITIES menu for your station/extension and use the next button to look for the handsfree setting use the key under the display to change it. The manuals are at http://wedophones.com/Manuals/Nortel/
Aug 30, 2014 | Nortel Norstar M7208 Telephone
What does dstnct rng mean on nortel phone
Different rings for internal (intercom) vs outside (central-office) calls.
Jul 10, 2014 | NorStar M7208 Corded Phone
Displaying "message" but not message in voicemail
THis is usually because it thinks that there is something there, but the code path to 'clear it" doesn't follow the same logic path. Sometimes, adding a new message - i.e. dial your number from elsewhere, to create a real message waiting, and then clearing that, resets this.
Nov 11, 2013 | Nortel Norstar M7208 Telephone
The "New Message Notification" will
To remove an incorrect New Message Notification, type
Feature + # + 6 + 5
Mar 08, 2011 | NorStar M7208 Corded Phone
M7208 call display not working hot sure how to program it. when calls come in it does not show who is calling
So is the display not working or are you trying to set up caller ID?
M7208 phones were delivered with the very first Nortel systems and if you have one of those, you're not getting CID. The CICS cabinet or higher requries a CID trunk card and IIRC 5.0 or higher software. If all of those are in place, as a minimum you can press FEATURE 811 to display CID info.
Carl
Feb 05, 2011 | Nortel Meridian M7208 Corded Phone
How do you change the time on the display for the M7208?
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316. The 4 top line/feature keys are now used for programming.
the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Nov 09, 2010 | Nortel Meridian M7208 Corded Phone
How do I retrieve recent incoming calls
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
Mar 27, 2009 | Nortel Meridian M7208 Corded Phone
Display always shows "Message for you"
Phone company should be able to fix this. Generally if you don't have the code to enter the phones system, you won't be able to clear it.
Nov 07, 2008 | NorStar M7208 Corded Phone
NorStar M7208 Corded Phone Logo
1,024 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
