HEIDELBERG QUICKSETTER 350 LASER FAULTS 1 - Office Equipment & Supplies
How to insert the code for the radio of my golf3 /1996
ENTERING SECURITY CODE
Most vehicles are equipped with Heidelberg V or VI radios that are equipped with a theft protection program. When the battery has been is disconnected or if the radio has been removed, the radio will lock-up electronically and cannot be operated until the security code is entered. On the Heidelberg V, if the proper code is not entered in six attempts, the radio will lock-up permanently and cannot be repaired. On the Heidelberg VI, two incorrect attempts will lock the radio for about 1 hour.
The Heidelberg V may have a code assigned at the factory or a personal code created by the owner. The Hiedelberg VI has a code assigned at the factory and entered by the dealer during pre-delivery inspection. New radios come with the code printed on a sticker but not entered into memory. All codes are 4 digits. To code the radio:
Heidelberg V
  1. Turn the radio ON . The radio should display the word SAF. DO NOT attempt to eject a cassette with the radio in this mode.
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear for about 3 seconds, then the display will go blank. Release the buttons then.
NOTE If the buttons are held too long, the radio will interpret this as an attempt to enter an incorrect code.
  1. Use the first four station selector buttons to enter the code. The first digit of the code is always 1. Each time the other buttons are pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When the radio plays and displays a frequency, release the buttons.
  3. If the code was entered incorrectly three times, momentarily disconnect the battery and try again. If the code is entered incorrectly three more times, the radio cannot be coded and cannot be repaired.
Heidelberg VI
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear and remain in the display.
  1. Use the first four station selector buttons to enter the code. Each time a button is pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When SAF appears in the display, release the buttons. The radio should play and display a frequency.
  3. If the code was entered incorrectly two times, leave the radio ON for one hour and try again. This can be repeated as often as required.
Oct 15, 2012 | 1996 Volkswagen Golf
Solutions for "heidelberg windmill" problems
this a topic for vacuum cleaner troubleshooting. And you are talking about the Heidelberg letterpress model T 10x15 , what do you need?
Jul 23, 2012 | Electrolux Epic 6500 Vacuum
Need rear panel drawing or install instr for Heidelberg CD51
Crutchfield has the manual available for download here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/023/023HDLCD51.PDF
I saw a picture in the manual showing where the various connectors plug in. You should be able to tell from there what the orientation should be. It was page 29 of the PDF.
Feb 16, 2010 | Blaupunkt Heidelberg CD51 CD Player
Heidelberg 2650 Linoscan scanner and XP
Hi - You need to install a driver for XP, you can find it on the following link:
Good Luck!
Jul 03, 2008 | Heidelberg Linocolor Saphir HiRes Flatbed...
Mac OS X software for my Heidelberg 1450 Firewire scanner ???
Try vuescan it say it works with your scanner http://www.hamrick.com/ it costs money but has a free trial
May 11, 2007 | Heidelberg Linoscan 1450 Flatbed Scanner
56 people viewed this question
jasbo
jasbo
