Question about Philips Televison & Video
Phillips dvd625/781 says load then says stop and nothing happens
With the cover off I load the disc and it spins longer that usual then it stops and the front says stop. After this it spins intermitently with nothing happening.
SOURCE: EMERSON DVD PLAYER CLICKING NOISE..DISC ERROR MESSAGE..HELP!!!
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
Posted on Dec 30, 2006
simplemitch
  • 752 Answers
SOURCE: insignia portable dvd player: disc not spinning
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Posted on Sep 23, 2007
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
  • 77 Answers
SOURCE: CD Player doesn't work; says "disc"
i would say that your lense is dirty and yes cleaning it might help
Posted on Feb 11, 2008
SOURCE: Check disc
Change your DVD player
Posted on Jun 28, 2008
Why does my CD player display "no disc"?
I had a similar problem with my DVD player. Cleaning the laser eye helped fix my problem. You can clean it manually if you are not afraid to remove the cover of the unit or you can try a cleaning disc. The eye can collect dust and prevent it from reading the ID sector of the music CD.
Jul 07, 2014 | Audio Players & Recorders
Playstaion 3 games wont load how can it be fixed. the clock (loading icon) stops. no errors appear no disk shows up.
listen for the disc to start spinning
if the disc spinns then its prolly just a dirty laser lens and if it doesnt spin could be a bad laser i doubt its the blu ray logic boad cause the ones i have seen that were bad the disk reading icon never stops, this has also happened on broken lenses where it never stops. ussually if it stops its bad motor or dirty lense.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Sony hifi wont play cd's
Optical lens requires cleaning.
Please put cd cleaner in tray and check if it cleans dirt on lens. Still same problem, then unplug unit from AC outlet, take off top cover of hifi system and clean lens with good quality cotton bud. hope this will resolve problem.
Jan 26, 2009 | Audio Players & Recorders
Does not play DVD
You need to open top cover and look inside dvd player cd tray. Does dvd / cd disc spins or having loading problem because grrrrr seems mechanical problem.
Let me know your finding to guide you further.
Thank you.
Oct 25, 2008 | Sony DVP-NS575P DVD Player
Phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Apr 19, 2008 | Philips PET724 Portable DVD Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Check disc
May 23, 2007 | LG DE9523P DVD Player
Televison & Video Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
