Question about GE WHSE5240D Top Load Washer
Washer wont turn on
My washer won't operate. It won't come on at all. Panel lights do not light up. Outlet checks fine: another appliance works in this outlet.
  • 2 more comments
  • Joyce Clemens Jun 12, 2007
    I tried your suggestion. My electric tester tells me that current is flowing through the appliance cord and into the control panel.
    Any other ideas?
  • tweetbird Nov 23, 2007
    push button swithch lights come on nothing else then lights move checked outlet everything whats next
  • apaseorosari Jan 03, 2009
    I have washer ge whse5240 and dont start only click's and that's all i check the power it is fine outlet too
  • Anonymous Mar 20, 2014
    LIGHTS ARE DIM AND GETTING 112V AT OUTLET
    President:
  • 1,294 Answers
Check the plug of your washer, the fuse in your washer's plug also. You start from there......
Posted on Jun 06, 2007
I have a new Maytag mvwc565fw. The Clean Washer Cycle was interrupted from a power outage and the unit is full of water and the lid is locked (light solidly illuminated). Trying to start any other cycle...
Resolution:If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Dec 27, 2017 | Maytag Washing Machines
Bush a126q / a146q pause light blinking programme won't start changed fuse Nd cleaned the filter what else could be wrong and what should I do?
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
follow the steps and fix it.
God bless you
Jun 09, 2013 | Washing Machines
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Control
May 28, 2013 | Washing Machines
The on and off switch wont turn on
Check Power
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace control
May 23, 2013 | Hotpoint Washing Machines
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
I HAVE POWER BUT THE CONTROL PANEL HAS NO POWER
see this causes and fix it. God bless you
Check Power
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Oct 02, 2012 | Maytag Neptune MAH6500A Front Load Washer
The digital display keeps flashing and wont work
Control
see the diagram attached and troubleshooting too.
Sep 30, 2012 | Washing Machines
46462 unit will not turn on
Hello anava214
Welcome
You said, your washer will not power up . Even the lights on the display panel are not turning on . And you have checked that the power outlet works.
Did you unplug the washer for 5 minutes and then plug it back in?
This can resets the system.
How old is the washer?
Oct 05, 2008 | Kenmore 46462 Front Load Washer
No panel lights!
Solution - MEASURE voltage in outlet with digital meter and if it is not ~115 V or very close do nothing - wait till it gets to norm.
Longer explanation:
I had similar problem today. Dryer fine, washer (front loader Affinity 6000) dead. Electric power there. Day before had no electricity for few hours. Turned out to be that this thing is sensitive to voltage. I have now from 101 to 103 volts and it needs something close to 115. I have almost disassembled it but it was hard to do and no manual on web (except to purchase for $15). So, after removing back paned and few screws from front I have turned my attention to my UPS I have for TV - it sometimes would blink with blue diode (means it is starting). I thought why... Then I have luminescent (energy saver) lamps around house and those are not sensitive to voltage so lights are fine. In bathroom however I have halogens and those seemed dim. This time I have looked at my tester again and noticed that it shows ~101.2 volts. So I am taking UPS from my TV and moving it to laundry, plug UPS to outlet, washer to UPS - washer still dead. I unplug UPS from outlet and washer comes alive...
Hope this helps.
Orest Dmytryshyn
Edmonton, Canada
Jul 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
GE WHSE5240D Top Load Washer Logo
311 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
