Question about Kitchen Ranges
Glass top kenmore does not seem to be venting correctly. When I open the oven door the heat and smoke will knock you down. There is also smoke that comes out from the back of glass top, on the left side of back. I can tell this has been going on for a while because the black area is discolored (a much lighter color). I am in a rental unit and have know Idea how long this has been taking place. Help....
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 28, 2012
SOURCE: how to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Posted on Jul 21, 2007
  • 833 Answers
SOURCE: KESC307 Oven Door
Hi Mcrae...
Generally, the procedure is a straightforward mechanical one.
First, check below the door for screws and remove them. Next, open the door and find the screws on the side and inside of the door. Remove them. Careful...when the door panel comes off, the door will be much lighter and will slam closed if not restrained. The panel should 'fall away' from the door. Have someone assist you here! At each stage, take a digital picture of the disassembly so you can assist yourself in putting it back. Clean the glass with a blue cleaner and buff out. Use a scrubby or very fine steel wool to gently remove any stains from the old glass you're reusing. Do this on a bedding of newspaper. Always handle glass by the edges.
When installing the glass, it should generally be apparent which way it goes in. Some glasses have patterns on them which correspond to the door opening...if it is the outer which is being replaced. Note them. There may be an up or down as as a result. Any foils or patterns are positioned to the direction you won't have access to later.
You'll likely need a second pair of hands to put it all back together. Take your time. Don't force anything. Tighten screws evenly.
Posted on Dec 03, 2007
SOURCE: How to Dismantle Oven Door to Clean Glass
yep but it isn't worth it in my opinion if you want to know i can tell you its a pain and usually you cant get it all off because its baked on but if you want to do it just reply to your own message and ill write procedure in the morning there is about three or four pieces of glass in there insulation all kind of stuff lol -tech17
Posted on Dec 29, 2007
  • 409 Answers
SOURCE: Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Posted on Sep 13, 2008
SOURCE: cleaning in between the glass on the doors
My Maytag Gemini double oven "ON INDICATOR" light won't go off even if everything is switched off. What can I do? Please help. Thanks.
Posted on Jun 17, 2009
The rarely-used back right burner on my glass top GE electric range doesn't work, but the rest of the burners and the oven seem to be working just fine. Is this something I can fix myself, or do I need to...
Open the oven door and look for screws that hold the cook top down. Take those out and the cook top lifts off from the front. Make sure that you unplug it first. Then you can see the coil that is not heating. IT could be the wires, connector or the coil itself that is bad.
Sep 27, 2013 | Kenmore 95592 / 95594 / 95595 / 95599...
Between glass dirty on kenmore glass top range
the door must be removed from the oven and taken apart
Oct 23, 2011 | Kitchen Ranges
We have a Kenmore double oven. Awhile back something spilled as it was being removed from the top oven, and spilled onto the door of the lower oven. Now the glass inside the lower oven door is streaked and...
Please follow the below steps
1)Open the door.
2)Check the hinges and let the door be opened in half way.
3)Use Philips screw head at hinges screws.
4)remove the door and take the inner part alone.
5)Just follow the picture for more help.
Clean it and place it again.
It is very simple you can easily clean it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 07, 2011 | Ovens
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
I have a wood burning fireplace and i am trying to find out how to work the side and top damper and vent to heat my home
top damper wide open and bottom damper wide open will burn very hot but too fast if you close the top vent off it will smoke in the house the idea is not to smoke the house but once you have a good fire lit with hot cinders to cut back on the top to ceep some heat in cut back on the bottom to burn slower if this is a metal box wood burner it should heat great if it is a standard fireplace with a glass door you need to be careful how close the flame is to the glass it can break. glass front fireplaces don't heat as well as an insert wood burner let me know if this is uesful or any more assistance needed thank you
Jan 05, 2009 | Heating & Cooling
Very simple I thought- Cleaning the inside of the glass on oven.
Don't have one here at home to look at, but the best way to go about that would be to remove the door from the range to work on in on a table, allowing access to any screws at the bottom of the door for disassembly and easier reassembly. To remove door: open oven door. Use a small screwdriver to poke in the small rectangular hole on the hinge and flip down the little lever toward the door. It is mostly hidden at the top of the rectangular hinge opening in the range frame. (do both hinges) Now with the levers down (locking the door hinge) you can lift and pull the door a bit, removing the door and hinge in one unit from the range body. Sounds more difficult than it is. It really only takes 10 seconds. To replace the door, just reverse procedure, remembering to flip the little levers back up after attaching door to range frame.
Nov 30, 2008 | LG LRE30451 Electric Kitchen Range
Cleaning Oven Door Glass inside face
First take the two inside screws out, (found at the top of the door) they will pop out when you have both sides off so make sure to take them all the way out so you dont lose a washer or one of the screws. The handle is actually secured by these 2 screws and will come off of the door when you remove them.. your metal door can bend slightly in this process, so be careful. as soon as the handle and screws are off you can clean inside of the 2 pieces of glass, also a good time to clean off the opposite side of the door behind the handle. only take the 2 screws off no need to remove the full door. I used a magic eraser to remove the grease and then I cleaned the glass with glass cleaner. I used a small vice to secure the door when putting the handle back on, but you could have someone to hold the piece togeather for you too. (I have a frigidaire stainless steel model)
Nov 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
How to take apart oven door
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
