Question about Whirlpool GR465LXLS Electric Kitchen Range
We put a new oven in the house there is 250 volts at the plug but the touchpad for the oven controls & clock does not work the plug is a three wire connection the ground circut screw did not have a connection to the pigtail ground we put a ground wire on the ground circut screw to the pigtail ground & the touchpad still does not work nor does the oven the top burners always did work can you give me any suggestion?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You seem to have a loose connection. This is the first issue I would tackle. Make sure you have proper 240 vac from the supply at the terminal block. Then you need to check l-1 and l-2 against white neutral for 120 vac. The clock needs 120 vac to properly light up. Then check the p1-1 power supply connection for 120 vac. between p1-4 connection neutral . If all this is solid, then double check the p-2 connector (p.c.b.). All pins need to be matched correctly and the pin connections at the jumper harness need to be checked to see if they (one- by- one) have not backed out slightly and making a partial connection. You can use a pick tool to remove the inner tang and remove the wire connector itself individually. Then pry up on the terminal tang and insert it fully back into the connector so it will make a solid pin connection. You will be able to tell if one is bent needing correction. At p-2 on the pcb board, pin # 5 is a brown wire with a non resettable fuse internally with the wire itself. Make sure there is continuity between these 2 -points as the fuse needs to be closed. This jumper goes to the clock p-7 pin connections.
Posted on Nov 28, 2012
jsrock516
  • 5911 Answers
SOURCE: oven display and oven are not working AT ALL
Most electric range ovens are controlled by the electronic oven control (EOC). If your oven is not working and there is no display on the clock, more than likely you have a bad EOC. The board is not serviceable and has to be replaced. I hope this helps.
Posted on Jul 25, 2007
catriver
  • 878 Answers
SOURCE: Whirlpool supercapacity 465 range won't heat up
hoops, it almost sounds like you lost a leg of power, L2. L1 is sending power to the board but but it's not making the loop. Too much of a coencidence that the burners and oven are not working. Check the cord connection to the oven. You should have 220V across the 2 outer terminals. 120V from each end to center terminal. Let me know what you find. Catriver.
Posted on Dec 16, 2007
  • 15 Answers
SOURCE: Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Posted on Dec 21, 2007
aborcass
  • 2651 Answers
SOURCE: whirlpool gold electric range control panel blinks w/all lights powers oven off
you say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
Posted on Mar 17, 2008
  • 311 Answers
SOURCE: Blank display on Clock/Oven Controls
Control is bad if it is getting power- needs to be replaced. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
LG ldg3016st has no power on main control panel
Did you have any power surges in the house? Any thunder storms?? even if you are not using a microwave, but it is plugged in , you see the clock?? That means it is getting power and running the clock so while you may not be cooking in it, it is actually using power to run the clock functions. So, if there was a power surge, it damages a part on the main board called the Low voltage transformer. It takes the 120 volts from the wall and drops it down to the voltages the board needs to operate, sometimes 5,12 24 or maybe 30 volts. If the primnary winding gets damaged from a surge of some sort. it will no longer light up if that small transformer was damaged. That can happen without even blowing the fuse as the small wires in the transformer were never meant to carry the 15 or 20 amps the fuse is rated at. So the transformer goes bad and the unit is dead but no blown fuse. Have to check the primary winding of the low volt transformer to see if it has continuity. If not, will need new main circuit board. Sorry But $$$$$
Sep 16, 2017 | LG Microwave Ovens
Only three buttons on the touchpad work,#1,7 and clock
try e spares for replacement pad e spares.com
Apr 20, 2015 | Microwave Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Start botton on touchpad not working
Try unplugging unit for 5 minutes then plug in and clear cancel. Re-set clock and tryto program. If this does not work, call service tech. A quilified tech will open up & test touch panel and control board.
Mar 27, 2012 | GE JES1142SJ Microwave Oven
Ge profile dbl oven keeps reading error message F7. Put cardboard card around ribbon cable on back of controller as advised a year ago on this site. We have moved it & changed it and now it works...
The F7 error code means that a button on the touchpad is stuck. What the proper repair procedure is,is to first replace the touch pad and if F7 returns replace clock (also known as eoc or control board) Do not take this wrong but a no point in my 30 years appliance repair career exchanging info with my coworkers or even factory trainers at training sessions have i ever heard anything about putting cardboard around the touchpad ribbon cable.
Gene
Aug 11, 2011 | GE Profile JKP56 Electric Double Oven
We recently moved, when we got to our new house we plugged in our stove. We turned on the burner and it didnt work, we tried the other three and they didnt work either.. Finally we tried the oven but there...
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
Feb 07, 2011 | Amana Kitchen Ranges
Apartment size brentwood electric range. The oven, 2 timers to the right of the clock and the outlet on front left have stopped working. Clock works, all top burners work.
Some of these ranges have two plugs, one for 240 volts for the burners themselves, one for the controls. Other issue, could have one leg of the 240 volt circuit not working, might get some heat, but not full power. Check fuses, just to be sure. In any event, you likely have two circuits: 240 volts for the power required to take care of the heat, and 120 volts for controls, timers, clocks. If only one plug, I'd expect to find a blown fuse within the appliance, or some other problem in the 120 volt circuit.
Not sure of your level of expertise to open up and trouble shoot electrical. Need to understand (1) how to kill power and (2) how to safely test a live circuit (at 240 volts.) Make sure meter is always set to 250 or greater volts, AC.
Oct 05, 2009 | Kitchen Ranges
LGR3330ADB Admiral touchpad display does not work
Usually this is due to a bad main clock/electronic control in the control panel but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.repairclinic.com
https://www.repairclinic.com/Maytag-Range-Stove-Oven-Parts
Jan 27, 2009 | Ovens
Kenmore elite oven lock
None of above worked for me. But, gave me a clue. I pressed the Stop/Clear button for apprx 10 sceonds. the "door locked" flashed for 5 seconds and then cleared and the door unlocked. Panel worked fine after that.
Mar 10, 2008 | Tappan TGF320 Gas Kitchen Range
Whirlpool GR465LXLS Electric Kitchen Range Logo
51 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
