Sorry it was to late i needed to crash but I need the drivers and manual for a Linksys Wireless-g Adsl Gateway Model WAG54G v3 router ? Gotta crash but any links might help thanks:)
  • 7,627 Answers
Try here for user manual and firmware:http://homesupport.cisco.com/en-us/support/gateways/wag54g
Posted on Nov 28, 2012
melnavz
  • 1226 Answers
SOURCE: Drivers for DI-524 Wireless Rourter D-Link
You can find donwload here:
http://support.dlink.com/products/revision.asp
follow the instruction.
me this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on May 21, 2008
raffaiel
  • 209 Answers
SOURCE: i have linksys router wireless-G
http://www-my.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=MY%2FLayout&cid=1169671629543&packedargs=sku%3D1166859947184&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=2954347184B10&displaypage=download#versiondetail
Open that link to download data sheet, user guide, firmware and set up wizard (driver) for your WAG200G.
Hope that helps.
Posted on Apr 22, 2009
stif_NEC
  • 441 Answers
SOURCE: very low signal (wireless maxg adsl gateway usr9108)
Have you tried changing the channel? This might help icrease your signal aslo avoid putting it near wall and if possible put somewhere higher (5-10 ft above the ground)
Posted on May 02, 2009
  • 252 Answers
SOURCE: How to configure Huwaei MT880 with linksys WRT120N router?
Try these steps:
  1. Shut down the DSL/Cable modem
  1. Power up the router (no cables just yet).
  1. Power up the modem and wait for the appropriate lights (power, ethernet, and activity – something along these lines)
  1. Connect the modem and router with an ethernet cable (if there is a WAN port on the router make sure to put the cable in this port).
  1. Connect Port 1 on the router to the network card on the computer using an ethernet cable and check to see there is a light at the correct port.
  1. Open a web browser, such as Internet Explorer or Firefox. Input your routers id (usually an IP address or an URL) in the browsers address bar and press Enter. The address bar is where you would normally see, for example, http://www.google.ca If you don't know the IP address (such as 192.168.1.1) or the URL, try going to the manufacturers web site and downloading a manual.
  1. Now, a window will open asking for a user name and password (these are given to you in the instructions of the router). For example, Dlink sets up some of their routers as, username: admin and leave the password field blank then press OK.
  1. Now you are in the configuration page of your router (wireless most probably). Here you can set the encryption, new passwords etc… If your not comfortable doing these on your own most routers have a wizard that you can follow.
  1. If everything goes alright and the settings are successful you can now try the wireless connection. Go to a machine with a wireless card, right
  1. At the computer with the wireless connection, make sure the connection is on You might be trying to connect to the network by using either the application that came with the router or windows wireless configuration. Right click the icon in the system tray and “view available networks”. If it comes up in a window saying “Windows is not setup for wireless networks” then you must right click on the correct icon in the tray.
  2. Now, in the list of available networks, click on the name of your network Click on "connect" and it should ask for your security id (the encryption code). Put in the code (usually twice) and click connect or OK. It should now be "acquiring anip address" and in a few minutes it should be connected.
Posted on Nov 07, 2009
rotorcrafts
  • 302 Answers
SOURCE: I have a TP LINK TD8817 V3 ADSL router and I lost drivers
I cant think of any reason that why it should not work with windows 7 as it has no link with the operating system being used.
Posted on Mar 06, 2010
My wireless is going on and off, what's the problem?
Frequent wireless disconnection can be caused by different factors such as:
• Wireless interference within the network
• Wireless settings of the Linksys ADSL gateway are still set to default
• Firmware is corrupted
NOTE: Before going through the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
To resolve intermittent wireless connection, you need to perform the following steps:
i. Reducing Wireless Interference
ii. Customizing Wireless Settings of the ADSL Gateway
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
I have a siemens 4200 adsl modem i had a net gear modem before and that was not working with wireless internet and now this modem wont let me connect wireless either only with the ethernet cabel. help!
Hello Mate,
the siemens speedstream 4200 is a DSL modem/Router which doesn't have wireless connection. So even tough if you have a computer equiped with a wireless adapter, you will not be able to connect wirelessly because the siemens 4200 doesn't act as wireless access point.
You may need next time to check first if the modem/router to buy support wireless (wifi g or n) and make sure that it's not only a modem, it should be also a router.
i attached here some references for you from the top brands:
1. Linksys DSL modem/Router with wireless N: http://www.linksysbycisco.com/MEA/en/products/WAG120N
2. Linksys DSL modem/Router with Wireless G: http://www.linksysbycisco.com/ANZ/en/products/WAG54G
You can find other brands as Dlink, Netgear ...
Best Regards,
Oct 29, 2009 | Computers & Internet
Iam running internet cafe i have a adsl internet connection, I have bought one WAG54G wireless adsl router and 8 port Netgear switch, i have establish 7 connection through the switch connected with router...
The internet is disconnecting that means the problem is with the router. you also said that the router is getting hot.
I think probably you can try to upgrade the firmware of the router.
Or if it is a new router then try to get it replaced from the store.
Click Here for more info about the networking
Oct 07, 2009 | Linksys WAG54G-UK Router
Appreciate any advice on how to set up Linksys Wireless G Router
here's a basic SoHo set-up.
But if your looking for manual, please provide me your e-mail address so that i can e-mail you.
Thanks.
Feb 09, 2009 | Linksys Wireless-G WRTP54G Router
Aculaser CX11F won't connect to wireless ADSL Gateway
Use this tip for a fast check list.
Connect to gateway using a Lan cable and be sure you can browse Internet.
Then create a specific SSID and check if you see it on WLan adapter
Then remove security from router and check if you connect,
let me know if you need more help
Feb 01, 2009 | Computers & Internet
Dear i can not input my vpi vci 0 / 35 can you help me please
If you have a WRT54G router then there is no option on the setup page where you can configure virtual circuits(VPI/VCI). What you need is a WAG54G(wireless G ADSL gateway) which is a A/DSL modem and router bulit in to one device, there you have an option to setup your virtual circuits manually. Now if your A/DSL modem functions as a gateway, just configure you the settings on the modem instead on the router then just set your Linksys router's internet connection type to Automatic Configuration DHCP and it should be up and running.
Dec 03, 2008 | Linksys Wireless-G WRT54G Router
I am a very untechnical person and I bought a wireless G Router thinking I could connect it very simply and make my wired broadband wireless. Unfortunately the modem I have, which was sent to me by Virgin...
I'm thinking you have the ADSL modem supplied by Virgin with only the telephone line port and an USB port on the back that goes to the computer.
In the case above. You need to buy a wireless router with a USB port connection. Or something like a Linksys WAG54G which is an ADSL and wireless router all-in-one.
Aug 16, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need driver for Linksys MRT54G Ver.2
Go On Google And Search Linksys Wireless-G MRT54G Ver.2
Driver And That Should Do The Trick
Jul 09, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
