Question about Miele G2142 24 in Builtin Dishwasher
G2142 service manual
I have been having intermittent issues with draining pump and the water leak detection tripping. So far, the issues have been 'resolving themselves'. Does anybody have a service manual available to check out if I just have a loose contact somewhere?
3 Suggested Answers
Rotu
  • 175 Answers
SOURCE: Dishwasher will not start
Check the drain pan area under the dishwasher, if it full of water it will trip a float switch and run the drain pump until the water evaporates or is removed by a shop vac.
Posted on Oct 03, 2006
KevinWhite
  • 1902 Answers
SOURCE: I have a Miele 851
Hello & Welcome to FixYa
If you have already cleaned the drain filter pump assembly located inside the bottom access panel completely and you are sure that it is not overflowing due to a bad float switch assembly located inside the bottom panel next to the pump then yes the recommended repair will be replacing the drain pump assembly. Please get back to me if you have any other questions.
Kevin
Posted on May 31, 2011
What means code FH in the console A/C Model DSC-F1253L-V Thanks
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
It can be caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning. Hope this helps
Dec 15, 2016 | Washing Machines
FH Error 9 minutes after pressing start.
F/H:
Condition
Or
Check/Repair:
Jul 24, 2015 | Maytag Washing Machines
My Whirlpool AWM 8120 front loader washing machine stops after working 6 minute in lcd panel show FH what the problem please ans? tanks tian from indonesia
F/H:
Condition
Or
Check/Repair:
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Jun 14, 2015 | Whirlpool Washing Machines
Have a FH error,, what can i do
F/H:
Condition
Or
Check/Repair:
  • If there is no water in the unit:
  • 1. Make sure that both valves at the water source(s) are turned on all the way.
  • If there is water in the unit:
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Nov 06, 2012 | Kenmore Elite 45986 Front Load Washer
Fills with water and stops giving error message HF
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.Press PAUSE/CANCEL twice to clear the display.
Oct 20, 2012 | Kenmore Elite 45986 Front Load Washer
What is error code FH
Hi Steve:
F/H error code
Condition: No water detected entering machine or Pressure switch trip not detected.
- If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed, or...
- If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
- Press PAUSE/CANCEL twice to clear the display.
* If there is no water in the unit:
* If there is water in the unit:
* If this is intermittent, it would be very hard to determine the cause.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Kenmore HE3T Washer
What does FH mean on a kenmore front load washer and where can i get a manual
F/H:
Condition
Or
Check/Repair:
Jul 20, 2011 | Kenmore Front Load Washer
My Kenmore Elite HE3 keeps flashing F H
F/H error is normally a malfunctioning flow meter. A good indicator is substantially higher water levels than normal, provided the flow switch has tripped its first set of contacts.
Condition
Or
Check/Repair:
Hope helps (remember to rate and comment this answer).
Jun 24, 2011 | Kenmore Washing Machines
What does error code H F stand for?
that error code means No water detected entering machine or Pressure switch trip not detected.
Or
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Service manual below.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No service manual
water filters in the hose attachment at the machine cloggs up. Sometimes fast. take off hose and clean the filters.
This is from whirlpool:
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Replace failed component.
Jun 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Miele G2142 24 in Builtin Dishwasher Logo
69 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
