Question about Pioneer VSXD814 Receiver
I have a pioneer dvd player I want to connect it to my pioneer VSX-d814 receiver using an optical cable. How do I set this up?
    Problem Solver:
  • 5 Answers
LAZA got a haircut .
Posted on Dec 21, 2009
I was using my vsx D510 with a hiteker dvd player
Each digital input is assigned a name and a function by you. You have to dig out the manual and assign the digital inputs.
My $.02. Why do you not want to use the coaxial imputs? There is no functional superiority of one over the other BUT coaxial is a) cheap, since it uses standard RCA cables; b) adaptable, since you can splice or split them among two devices; c) not delicate or prone to failure due to tight bends. I share one coaxial input between two digital device with an RCA splitter cable. Just have to make sure to turn the one I'm not using OFF. Try that with optical.
Dec 21, 2009 | Pioneer VSX-D510 Receiver
Pioneer VSX-D509S 5.1- No voice audio on DVDs
try the dvd player settings to bitstream out in setting menu ok not pcm best to use coxal cable to get fiull 5.1 suround
Jan 20, 2008 | Pioneer VSX-D509S Receiver
Pioneer VSX-D307 Receiver - no audio using DVD inputs
Sometimes the default on receivers in dvd mode will be digital. Make sure you are on an analog input or just try an optical or digital coax out of the dvd player and be done.
Jul 06, 2009 | Pioneer VSX-D307 Receiver
Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Sep 19, 2008 | Pioneer VSX-D608 Receiver
Pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Mar 21, 2008 | Audio Players & Recorders
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Optical Audio Connection
My only thought is to make sure there are no protective covers over the ends of the optic cable. They often come with plastic caps. Either that or you have a bad optic cable if neither the DVD or DVR work with that cable. Good luck!
Dec 26, 2007 | Denon AVR-2106 Receiver
Pioneer vsx-d510 coaxial dvd connection problem
I recommend you use an optical connection. Your VSX-D510 has only one optical input, but I believe it is assignable. Use a good optical cable and connect directly to your DVR. Follow the manual to assign the input and it should work.
Good luck
Nov 16, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSXD814 Receiver Logo
80 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
