Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
Need a stand/base for this philips tv - Philips 50PF9631D 50 in. HD-Ready Plasma Television
Hi I need a base or stand for this model
I need a base or stand for this model. Called Philips and they are no longer making the part. Any suggestions.
Jul 30, 2011 | Philips 42PF9431D/37 TV
How do you assemble the stand to the tv
This is a pretty easy job.U have the four Philip screws that came with the tv base stand wright?U have a Phillip screw driver wright?Just put the base stand into the tv make sure all the screws holes lines up between the tv and the base stand holes.Than just tighten the Phillip screws with the Philip screws driver,than u are done.
Jul 14, 2011 | Samsung LA40A450 40 in. LCD TV
Not sure how to remove bottom stand from the tv
Lay the tv down to flat cushine surface like a bed maybe.Take all the tv Philip screws out of the base stand,give it a little tuckles like fordward or backward of the tv base stand will come wright out.
Jun 17, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
I need to know where I can buy the base of a 47-inch Philips TV
Tries websites like Amazon.com,Ebay.com to buy a used or new tv base stand.
Feb 17, 2011 | Philips 47PFL6704D LCD TV
How do I install the base stand?
Just put base stand into a hole of the main LCD tv unit at bottom base hole and make sure all the screws holes lines up.Put in those holes with 4 or more philips screws on those holes and now just used a philip screw driver turn it clockwises to tighten those philip screws for it to hold on to the base stand.
Feb 05, 2011 | Samsung LN46A530 46 in. LCD HDTV
HOW DO YOU GET THE TV STAND OFF A UMC UX26A TV
Check the tv back cover at near around the base stand area.Lacate all screws near or at the base stand,spray some WD40 in each screws holes and wait like around ten mins.Take a Philip screw driver take out all the screws out in the srews holes.Take ur hand slicely push it foreward and pull it back.Now u should have no trouble taking out the base stand.
Dec 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
Need to know how to attach the stand, I have the parts that came with the TV but no instructions.
Very easy to attach the base.Just put in the base in long square whole matches up all the screws holes and put in like 4 Philip screws in and tighten it with a Philip screw driver that should have the base stable and hold the tv.
Jul 07, 2010 | Insignia LCDTV26 26 in. Television
I need the base stand for my tv cus been wall mounted and now need it on stand and i lost it
Not all Philips tv's will use the same stand. First, look on the back of the set for the model number. You can purchase most television parts, including stands and base assembly at http://www.partstore.com/
Jul 29, 2009 | Philips Televison & Video
Phillips 42 inch tv
Vendor nap.jpg Part Number 310430814621 Description Stand Base
Tritronics, Inc.
(800) 638-3328
call these guys and they should be able to locate it for you or at least tell you where to get one.
Mar 18, 2009 | Philips Televison & Video
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
