Question about Toys
I need a 9 volt adapter for my gemmy santa - Toys
4 Suggested Answers
SOURCE: Gemmy Santa Bear mouth does not move
The repair listed is just the start. You can, with a lot of careful work, remove the bottom of the mouth, but your work has just started. You will then have to remove the rod that holds the mouth rod to the mouth slide lever "spine". It has a small spring at the top and I found it easier to disconnect the spring prior to repairing the unit. It is glued in quite well so I suggest a Dremel tool to cut the sides off which you will enable you to remove the rod. Then you can remove the head from the spine without difficulty. Now you will see that the problem is as stated, the string that pulls the mouth open has separated from the motor shaft. The cause of this problem is that the grease that the mouth slide lever rides on has migrated to the string, and then, softened the glue, which allows the string to separate from the motor shaft. Now, clean the shaft and replace the string. The original string is nylon. You should use similar material, NOT cotton string or a rubber band. You can't use the old string as it is soaked with lubricant. Use a good super glue to bond the new string to the motor shaft. Next, test the unit to make sure that the mouth slide lever operates properly. Reassembly of the unit would be: remount the head to the neck, then reattach the mouth rod to the mouth and then reattach the mouth and rod to the mouth slide lever.
Posted on Aug 29, 2009
SOURCE: I have the 48" gemmy singing, dancing santa. We
I have the same problem. Ever find an answer?
Posted on Nov 28, 2011
  • 5 Answers
SOURCE: i need instructions on how to pop up my gemmy
It is suposed to pop up once you press on its shoulders. Once you press them both down you will hear two clicks and release and it will pop up. Mine was jammed and when I pressed it down on the shoulders only one side would click, the other side would not click so Santa did not pop up to full size.
It was jammed on the white area of the stocking, the material got tucked inside the click mechinism prevent it from making proper contact. To fix it I simply pulled the white stocking material up (as if you are going to roll the pant leg up) and then when I pushed the shoulders down after that it opened up just like it should!
Posted on Dec 06, 2011
Can you buy the power cord for the gemmy santa clause
Any the adapter plug is identical to a rechargeable drill and the volts for it are 9V hope his helps
Jun 17, 2014 | Gemmy Life-Sized Animated Santa
Using wrong adapter on my Gemmy Animated santa , What will this cause Because I am having problems but some things work? But the Hips won't move . I am using a 12v adapter but it is suppose to have a 9 v...
Using the wrong adapter will likely shorten Santa's life span. It is best to use the recommended adapter because using the wrong one may have fried his hips among other things.
Nov 08, 2013 | Gemmy Life-Sized Animated Santa
I need an instruction manual for gemmy lifesize singing and dancing santa
The shoulder thing worked! thanks so much!! i was all over that thing!
Dec 10, 2012 | Gemmy Life-Sized Animated Santa
Santa will do noyhing
WE only have h im...need to purchase a adapter to plug in. Seller said mmusic did not work. Would like to get him to grow some. Please help
Nov 26, 2012 | Gemmy Life-Sized Animated Santa
Singing dancing Santa won't stop dancing
My neighbor just gave me 1 of these... needed the adapter... 4.5 Volt 800 mA and be sure to get one where you can reverse the polarity if necessary. (polarity is: + ---O---- - ) I had to do some "modifications" to the base as my adapter had an "L" base & wasn't long enough - straight adapter would have been better... Santa wouldn't stop singing/dancing- hmmm. Cleaned the motion sensor lens and then had to cover the modification hole in the base to completely darken the interior of the base. Viola now the motion sensor works... is driving the dog crazy!!
Nov 06, 2012 | Gemmy Life-Sized Animated Santa
Does anybody know what size plug/powerpack I need to order for my 5ft singing dancing santa! please help I'm desperate! Julie :-)
You need a 9volt small transformer. People have them in the basements every where, or a friend will have one from some other toy. Lots of them around clearly marked for 9 volts. These are low amp cords. Hope it helped. Joe
Dec 13, 2011 | Gemmy Life-Sized Animated Santa
Toys Logo
69 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
