Question about Singer Featherweight 132Q Mechanical Sewing Machine
Fabric won't feed threw machine
Fabric won't feed threw machine can't go forward or backwards
  • Singer Master
  • 7,365 Answers
It sounds like the feed dogs are not working, can you see them in the
needle plate area? you should be able to see them and feel them
with your finger. what is the name and model of the sewing machine?
Posted on Nov 29, 2012
wcbotha
  • 92 Answers
SOURCE: Needle stays in one place. Fabric does not feed
There is a latch under the the feeder lpate next to the bobbin lift it up to lift the feeder feet. wcbotha@yahoo.com
Posted on May 12, 2010
RickE1
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
  • 6 Answers
SOURCE: Feeding teeth on machine
There is either a "darning" option knob on machine, lower right hand, or a metal rod on top right that you use to lower the feeddogs.
Posted on Apr 26, 2009
chrismyers67
  • 53 Answers
SOURCE: i have a singer simple sewing machine and when i
Sounds like your feed dogs are in the down position. Make sure they are in position "A" (see picture)
Also, make sure your length dial is set to a medium setting (Usually 1.5 - 3)
Posted on Jun 07, 2010
  • 54 Answers
SOURCE: Suddenly started sewing backwards (fabric feeds
is your machine sitting in button hole.
Posted on Aug 17, 2010
ELNA 1000 not moving fabric through.
Have you got a tangle under your fabric? If so, release the fabric and rethread your machine, making sure the foot is up during threading. Otherwise check the feed dog under the foot. There's usually a switch somewhere that brings the feed dog up or down. If it's down the fabric won't feed. Another point, what type of fabric are you sewing. If it's leather or leatherette you'll need to use a roller foot. Hope this helps.
Oct 03, 2017 | Elna Sewing Machines
After setting up the buttonhole attachment, etc. I press start and the needle goes up and down but it does not move or make the buttonhole. How do I fix this?
Please provide a make & model of machine. We can't begin to address your problem without more information.
Check that the feed dogs are in the raised position or the fabric will not move.
Aug 03, 2016 | Sewing Machines
Prelude. How can I adjust a feed dog to go left to right?
Sewing machine feed dogs generally do not move sideways. They move only forward or backward. Embroidery machines will stitch in all directions but only because they use hoops and not feed dogs to move the fabric. If you need the stitch to go a different direction, you can try rotating the fabric. Free motion quilting uses your hands to move the fabric under the needle but the feed dogs are not in use.
Mar 10, 2016 | Sewing Machines
Fed dogs will not move fabric
hi, do a web search for feed dogs and put the make and mode lof your sewing machine in there along with the words how to adjust or how to repair....it should throw up loads of results
Jul 03, 2015 | Sewing Machines
Feed dogs will not move fabric
So right! You are brilliant!
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Jan 06, 2013 | Sewing Machines
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
Won't sew, the fabric stays in one spot
is the problem the fabric is not moving forward but staying in one spot? which would mean the feeddogs need to be checked to see what position there in --up for sewing---down for darning
or the thread is not feeding into the machine?
Feb 10, 2012 | Janome DC3050 Computerized Sewing Machine
My Janome Harmony 1017 won't sew all the zigzag stitches. Stitches 5,7 and 8 bog down after just two or three stitches because the fabric isn't moving through the machine. Any suggestions?
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
Aug 29, 2011 | Janome Harmony 1017 Sewing Machine
CI just got my sewing maching six month ago and now for the first time it giving me problem . whenever im sewing the fabric won't move please please !!! help me to fix the problem.
in the needle plate area you'll find the feed dogs, they move the fabric forward as you sew, they should be up to sew . most sewing machine have a lever or knob that can be moved to change the feed dog position, unless then knob is broken
Aug 04, 2011 | Sewing Machines
Singer Featherweight 132Q Mechanical Sewing Machine Logo
139 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
