Question about Turbo Air TMW-1100M Green World 1000 Watt Commercial Microwave Oven
Microwave wont turn on
The microwave stopped working and will not turn on. Like it has no power
My Frigidaire microwave model PLMV169DCB turn table stop working & wont heat up
Thank you for your inquiry, Justin!
From the information you have provided your Frigidaire microwave is not turning and it has stopped heating up. It sounds like the motor, magnetron, or control panel may need to be replaced inside of your microwave. This could also be a miscommunication within your microwave and a reset could help clear it out. You can reset your microwave by flipping the household circuit breaker off for at least ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Apr 06, 2015 | Frigidaire Microwave Ovens
Microwave wont turn off
Or you replace (let replace) the switch, or you replace the complete microwave.
I don't think you have that many options, if you want to use a microwave.
Oct 21, 2014 | Oster OGB8902 0.9 Cubic Foot Microwave...
Model 85610 shut off and won't turn back on
  • Magnetron failure
  • Door interlock failure
  • Control board failure
  • Internal fuse failure
Jul 22, 2017 | Kenmore Microwave Ovens
Turn table stop turning and wont heat
Your oven has a couple of switches inside that are operated by the door latches. One of them controls the power to the turntable and magnetron tube power transformer. The switch is either out of adjustment (which can happen if the oven door gets closed real hard) or is bad. I would suggest letting a professional check the oven and repair the problem. Door repairs have a direct effect on microwave leakage and it's better to have them done safely.
Dec 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped working, no power. Checked
There are two thermal fuses.
One is located on the magnetron and another one is located on top of the left side of the cavity under the air duct. The microwave has to be removed from the cabinet to access the second one.
The problem turned out to be a 20 amp fuse that I was able to replace and the unit is working fine. Sometimes a blind squirrel finds nuts.
Aug 24, 2009 | Kenmore Microwave Ovens
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
MICROWAVE OVEN
Bad power diode, bad power capacitor or bad magnetron
Google on 'microwave not heating' and you'll get some sources of information
Dec 13, 2007 | Microwave Ovens
Turbo Air TMW-1100M Green World 1000 Watt Commercial Microwave Oven Logo
22 people viewed this question
Top Turbo Air Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Turbo Air Microwave Oven Expert? Answer questions, earn points and help others
