Question about Sony CDX-GT11W Car CD Player
Dolby bnr stereo factory wire harness
I need a color coded wire diagram to splice my Sony Xplod into my 1996 Codge CaravanDolby bnr wire harness
  • 323 Answers
SOURCE: SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Posted on Apr 21, 2008
  • 152 Answers
SOURCE: I need a color code for a Sony Xplod CDX-GT23W.
Guessing that you don't still have the owners/install manual.
On the back of the head unit there should be a group of unused/unconnected wires (with any luck they will be marked), one or more might be an amp turn-on or power antenna lead, so I suggest (with the unit turned on) testing each wire with a DC voltage tester so as to identify and separate any leads supplying 12+ volts. the remaining group will consist of speaker leads. Trial and error testing will determine the proper L & R rear speaker leads.
Good luck
Aduz
Posted on Mar 30, 2009
  • 1126 Answers
SOURCE: Need A wiring harness diagram for sony CDX-GT300
Sony head units use either a 9 pin connector, link below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C285614
Or a 16 pin connector, link below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C217600
And here is a kink to your installation guide.
http://www.docs.sony.com/release/CDXGT300_Installation_Guide.pdf
And your Operating Instructions.
http://www.docs.sony.com/release/CDXGT300.pdf
Posted on Jan 09, 2010
  • 211 Answers
SOURCE: I need the wiring diagram for Sony Xplod CDX -
I think this is what you are looking for:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT310&LOC=3
Posted on Feb 22, 2010
  • 11 Answers
SOURCE: need a wiring diagram for a sony cdx-gt08 it is
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Posted on Mar 14, 2010
Stereo wire codes diagram for a 1993 Ford Aerostar
Its easier if you get the $6 harness piece and attach it to the stereo harness and plug it in. Than to splice the wires on there. But here is the wiring color codes http://www.the12volt.com/installbay/stereodetail/795.html
Jan 26, 2015 | 1993 Ford Aerostar Extended
Sony xplod stereo wiring diagram
Yes you need to turn on the BOSE amplifier in the car to hear the sound. The wiring diagram is actually on top of the factory radio
You will need a 12v trigger to turn the amp on. this is assuming you have all the speaker (inputs) connected to the output from your new deck.
Sep 09, 2013 | 2001 Audi TT
Need free Wiring Diagram for a Chrysler 300M. want to use factory plug in for stereo. Installing a Sony Xplod cdx-gt300
You can buy a harness adapter at most big box stores ( Best Buy, Walmart and so on. It will have a wiring/color code, and once attached correctly to the new head unit, it will be plug and play. Good luck.
Sep 01, 2013 | Cars & Trucks
How do you hook up a bt39u radio
get a wiring harness from an auto store they usually have one for every car manufacturer and for sony decks they need to be converted from they're own pins to the standard audio deck wiring harness and if not most cars have little tags on the wires telling you what they are, red = 12v constant yellow= 12v switched green = earth black = earth and all the other colours are usually speakers and blue will be remote switched hope that helps
Apr 04, 2013 | Sony Xplod Mex-bt39uw Blue Tooth Auto...
I have a toyota trueno 1992 and i want to put a new stereo in it
Go to the auto parts store and get a wire adaptor made for a 1992 trueno. It will plug into your factory harness. The wire colors are prematched to your sony and other aftermarket stereos. Just match the wire colors, splice with connectors making sure no wires are exposed. (A little electrical tape for good measure around splices helps). Then it just plugs in. If your factory stereo has mounts that screw onto the radio, unscrew them and attach them to the sony. Remove sleeve from radio and discard. The screw holes are already on the sony.
Dec 29, 2012 | Cars & Trucks
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
Jun 07, 2012 | Lincoln Cars & Trucks
Im putting n a stereo but i dont no the color code
The stereo side of the wires should be labeled. Check out the12volt.com for a wiring schematic for the truck side. I advise against cutting and splicing wires for a stereo installation though. They make inexpensive harness adapters that will allow you to splice into the stereo harness without cutting into the factory wiring.
May 23, 2010 | 1998 Dodge Ram 1500 4WD
Need a wiring diagram to install cd player
If you buy a wiring harness from this guy he will send you a wiring diagram. Copy and paste the web address2_bing.gif.
Here you go bud:
http://cgi.ebay.com/SONY-wire-WIRING-Harness-XPLOD-XR-CA430-CDX-MP30-sn6_W0QQitemZ200417888633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea9d64979
Jan 13, 2010 | Sony CDX-SW200 AM/FM Compact Disc...
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
Sony CDX-GT11W Car CD Player Logo
89 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
