Question about paychex.com
Can not run paychex on google chrome - paychex.com
I'm trying to download a check stub onpaychex.com
I am too and cannot even get the paychex.com site to pull up!!! I am beyond frustrated!!! it is my only way to get a paystub!!!! can't even get a phone number to talk to someone!!!!
Jul 03, 2014 | paychex.com
Error 3
Error 3 is a failure to communicate with Google Update.
  • Check if you're running Vista/ 7 and you have configured Google Chrome to always run as administrator. This is a known issue with the Google Chrome auto-updating mechanism and can be avoided by simply running Google Chrome as a normal user. Additionally, keep in mind that for security reasons we recommend that you don't elevate the privilege of Google Chrome to administrator.
  • You can also try reinstalling Google Chrome
Update server not available
Apr 13, 2014 | Google Chrome
Wich version of google chrome supports cooliris/win7 sys64
Make Google Chrome Work on Windows7 64 Bit
Right Click on the Google Chrome Shortcut Icon
Click on Properties and Select the Shortcut Tab From the properties Window
In the Target Field put -in-process-plugins right after chrome.exe
Click On Apply to save the changes and Then Click on OK to close the window
Now Open Google Chrome It would work on your Windows 7 64 Bit.
http://www.chromeplugins.org/tips-tricks/how-to-run-google-chrome-on-windows-7-64-bit/
hope this helps
Oct 10, 2012 | Acer Aspire Z5771 23 Inch Touchscreen...
Cannot access paychex.com
I am able to access it just fine. Do you mean you can't get to the website at all or log in? If your having issues logging in you will need to contact the company directly. If your having trouble getting on the website try deleting your history.
thank you,
Lee
Jul 11, 2011 | paychex.com
How do i change to google browser
Navigate to http://www.google.com/chrome and press the big blue button.
The browser may ask you about what to do with the download. If there is a button "Run", click on it and allow any operations performed by the installer. At the first launch of Google Chrome, you will be asked whether Chrome should be the default web browser. Click on Yes, and there you are.
Jun 28, 2011 | Google Chrome
Error 102 (net::err_connection_refused): Unknown error. - This Shows up everytime i try to open Google chrome. - I tried running spyware bot and re-installing google chrome but it still doesn't...
A sudden "error 102" from Chrome while Firefox continues to work is a very common sign of a hijacked system.
Some solutions to an "error 102" from the Chrome website include:
checking for malware clearing your Google Chrome cookies making sure Chrome is excepted in the firewall settings ensuring correct proxy settings
Because FF works and Chrome doesn't, I would think that some malware has adjusted your proxy settings in Chrome. This is relatively common.
Go to Control Panel, click Internet Options. Under the Connections Tab, click the button "LAN Settings". Make sure the "Automatically Detect Settings" box is checked. Make sure the "Use a proxy server for your LAN" is UNCHECKED. Hit "OK" and all that jazz to make sure your settings stick.
If you still have a problem, make sure your computer is completely clean, clear all your cookies and stuff, and check for any programs that might be blocking Chrome's access (firewalls and antispyware). Hope this helps somebody!
Jul 02, 2010 | Google Chrome
When Google Chrome will support Selenium IDE as an extension?
There is one trick to use selenium IDE script in google chrome and IE. You can run selenium IDE script from command line to run it on gchrome. Here are the steps for the same. http://software-testing-tutorials-automation.blogspot.in/2013/07/steps-of-running-selenium-ide-test.html
Mar 27, 2010 | Google Chrome
Google chrome installation
Yes, both web browser work in windows XP.
Here is the download link for Internet explorer 8 for Windows XP
http://www.microsoft.com/downloads/details.aspx?displaylang=en&familyid=341c2ad5-8c3d-4347-8c03-08cdecd8852b
Here is the download link for Google chrome
http://www.google.com/chrome/thankyou.html?hl=en&brand=CHMB&utm_campaign=en&utm_source=en-ha-apac-in-sk&utm_medium=ha&statcb=
Dec 28, 2009 | Dell Inspiron 1545 Notebook
paychex.com Logo
171 people viewed this question
Top paychex.com Computers & Internet Experts
David Payne
David Payne
Are you a paychex.com Computer and Internet Expert? Answer questions, earn points and help others
