Have a honeywell hot point gas furnance how do I bleed the lines
  • 57 Answers
Never heard of bleeding them, but everything i\'ve bleed and its been alot in 60 years...anyway the way that i was taught and have seen,you go to the last movable joint on the line,loosen it a bit ....but 1st make sure theres no open flames,sparks anything of that type ..in fact if you have aluminium pipe wrench,they don,t spark....anyway after pipe is loosened things are safe all around,airy area if possible...turn on gas a little and loosen the joint a little more until you can smell gas at the loose fitting,hand tighten joint,shut off gas all in same motion,just to get it done...Then carefully tighten joint,most heater pipes are using spark proof piping anyway......your through bleeding it .But check other sites or opinions to double check if you want...
Posted on Nov 28, 2012
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
Honeywell 8600m I have a spark but no gas to light spark
Is this LPG or natural gas? and is it a fan forced air? if it is a wall mount room heater it takes some time to bleed the air out of the line before you can get the pilot light to catch the first time.
May 25, 2014 | Heating & Cooling
What is local set point
fault code 36 water runs hot for about 5minuets then registers this fault code and hot water goes off. water pressure seems ok and gas supply is alright.
Feb 02, 2014 | Honeywell Water Heaters
Hot water baseboard, third level heat not working
Raise water pressure to 12 and bleed out of the return pipe for that zone until you get all the air out!
Jan 09, 2014 | Honeywell Armstrong Gas Furnace Flame...
GAS FURNANCE NOT KICKING ON HEAT CAPF024A2A
Do you know if they purged the gas lines? Sometimes when the meters are changed air can build up in the gas line
Dec 07, 2012 | Heating & Cooling
Honeywell heat/cool thermostat keeps turning furnance on
This is not the thermostat, it is most likely the controller in the furnace.
Aug 10, 2012 | Honeywell Heat/Cool Thermostat
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 07, 2011 | Honeywell Water Heaters
My gas furnance will not stay on
This is probably the thermocouple that makes sure the flame is ignited. they can be cleaned with sand paper usually. it is located beside the burner within the fire. It will be very hot!
Apr 08, 2009 | Honeywell Electrical Supplies
Furnance will not heat
Check your voltage going into the gas valve. It should be 24-27 volts. If it is to low the gas valve will chatter. If the voltage is strong enough you have a bad gas valve.
Dec 09, 2008 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
