Question about Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515
Trips breaker after a few seconds of run time.
After many hard years of solid service my Porter Cable air compressor modl cpf6020 has its first problem. after a few seconds of running it will trip the breaker. the problem is not the breaker or the curuit. I have even tried running it on a 30A curcuit using my generator and although that will gain a few more seconds of run time, it still trips the breaker. I had the capacitors tested. the run capacitor was bad so i replaced it, and replaced the start capacitor just for fun so both are new. it seems to me that the start capacitor is not being cut out of the curcuit once the motor is running but i dont know how to test that theory. i have tested all wiring connections and all are good. the Centrifugal switch seems to be in working order (all the moving parts move correctly) but I dont see how the Centrifugal switch physically interupts the curcuit. directly below the switch is a plastic part that 1 wire from each capacitor connects too and a flexible metal component that is the "switch". does anyone have a pic or digram of how this switch works so i can make sure its not broken or missing parts? any help or ideas much appreciated!!!!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
Start capacitors are disconnected when it is reach a full RPM.
Use a AVR tester - measure AC voltage across capacitors. It shall be off in a few seconds after is running.
If not - centrifugal switch or its components are problem.
Posted on Oct 19, 2017
SUPERMAN_B_1
  • 294 Answers
SOURCE: porter cable pancake compressor seems to run weirdly
hello, it sounds like your pressur switch is going bad or your have a air leak on the tank or from the tank some where. does your pressure gage read that the tank is fully charged ?
Posted on Mar 29, 2009
aquaman987
  • 927 Answers
SOURCE: I have a C2150 4 gal compressor from Porter cable
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
Posted on Dec 19, 2010
compman66
  • 169 Answers
SOURCE: Trying to wire up my new air compressor, need help with wires.
If you are trying to connect power lines directly to the motor then stop what you are doing, I advise you refer to the owners manual for correct wiring of the compressor. I would highly advise that you seek the service of a professional to hook it up. otherwise you could damage the equipment or worse yourself.
Posted on Dec 09, 2009
mxc2
  • 146 Answers
SOURCE: how to remove muffler intake from Porter Cable CPF6020-1 air compressor
To remove the air filter intake muffle you will need to remove the 4 screws that hold the head on to the pump.
There is a O-ring under the head you will want to put a little vasoline on before you reassemble the head back to the pump.
The new muffler kit should be the KK-4981
Posted on Oct 11, 2012
Healeyman
  • 1198 Answers
SOURCE: porter cable pancake compressor trips breaker immediately when turned on.
Sounds like the motor is burned up.
Posted on Nov 26, 2013
I have a craftsman 22 gal 5 hp air compressor that runs about five seconds when I turn on and blows breaker to receptical every time..makes air for the little time it runs
check the amps requirements for the compressor, it should be at least 20 amp breaker without much else on it running at the same time.See what else goes off when breaker trips
Apr 13, 2016 | Craftsman Air Tools & Compressors
Porter cable cffn25 won't run. Trips breaker
The little compressors were not built for continuous duty. The pump probably seized, or the motor burned up, or both.
Nov 25, 2013 | Porter Cable Air Tools & Compressors
I have a 5kw generator it was working fine I use it on the oil fields to power my little rv suddenly every time I turn on the air con it trips the breaker and now im using a air compressor and at first...
A number of things can cause this. A sit worked before !
Basically:
Engines get older and can't hold HP which causes the rpm to slow and voltage dip, this causes a current increase and trips.
Breakers also get weaker especially if they trip a few times
HVAC and compressors pull approx 6 times the current to start as they do to run, once they have run a while, they build up higher head pressures which cause harder starting and more current draw, hence the breaker tripping.
It's hard to pin point which is the actual issue, but these all contribute.
Aug 08, 2013 | Briggs & Stratton Power Products 5,550...
My porter cable 200 psi air compressor will not run
The curcuit breaker on the motor. Probably a little round button that's about the size of a screw head.
Jan 04, 2013 | Porter Cable Air Tools & Compressors
How to remove muffler intake from Porter Cable CPF6020-1 air compressor
Sep 10, 2012 | Porter Cable Air Tools & Compressors
Air compressor is about 10 years old. Used for light duty work only. It trips the breaker in the box after about 1-2 seconds running. Has been plugged into same oulet never moved. Tried in different...
Hi hbkopen31...
Your problem sounds like it is the motor giving a problem.
Unhook the belt from the compressor and run the motor by itself...check the compressor to make sure it is not dragging the motor too much making the amps go up and tripping the breaker..
If the motor runs with the belt off of the compressor, then let it run for at least an hour, then put the belt back on and try it again...if it trips again, then replace/rebuild the motor as it is faulty.
Also check the motor capacitor sometimes they fail..
If the motor still trips the breaker after removing the compressor belt..replace/repair the motor as it is faulty.
Please take time to rate me
Sep 05, 2011 | Garden
I have a C2150 4 gal compressor from Porter cable with 2hp peak and 1.2hp continous rated motor. The problem is that I can not run the compressor on a 15amp circuit with out tripping the breaker. It even...
Gary
Dec 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Porter cable pancake compressor seems to run weirdly
Mar 28, 2009 | Porter Cable Cable Brad Nailer and...
Air compressor trips breaker
check the ground wire most common mistake
Nov 18, 2008 | Air Tools & Compressors
Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515 Logo
113 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
