Question about Denon AVR-2807 7.1 Channel Home Theater A/V Receiver
Connect wireless headphones to avr-2807 without using front jack
    Sergeant:
  • 344 Answers
It isnot possible, That is the only way,
Posted on Nov 28, 2012
    Genius:
  • Denon Master
  • 1,054 Answers
Connect them via the back panel cd-r or tape out jacks. Depending on the connection options on your headphone you may need to get an adapter cable to go from rca to headphone jack.
Posted on Dec 27, 2012
2 Suggested Answers
SOURCE: connecting wireless headphones
stop connecting
Posted on Jul 06, 2009
Denon avr-587 shows h/p only in display,no audio out.
The problem usually is very simple - bad connection in head phone connector located on the front of the unit.
You need to find any headphones with 1/4 jack and plug it into receiver several times. It clean internal contacts in the connector and your receiver will work again. Good idea to use contact cleaner during the process. Thanks.
Jan 11, 2011 | Denon AVR-587
Can I connect wireless headphones to one of the outputs on my receiver (like tape out) instead of the headphone jack in front?
Sure but I dont know if it will down convert the digital audio out of the analog audio Tape out. For instance, if you are using HDMI from your cable box it might not be able to go through the tape out portion. You may also have to run left and right analog audio cables from each source and set the unit to auto input.
Hope I helped!
Nov 21, 2009 | Denon AVR-2807 Receiver
Can't get the sound to work on my TV using the Denon AVR-2807
In the 2807 the HDMI out is a video out only. Audio is not processed through the HDMI output.
If you are using speakers it is best to adjust the playback modes to stereo if you are annoyed with surround sound modes.
Please comment if I helped.
Oct 04, 2009 | Denon AVR-2807 Receiver
Wireless headphone connection to multiple components?
Cat,    Splitting an optical output is not recommended.  In fact it would require an optical patch bay, which would be overkill. You could use the headphone output on the front of the Denon AVR3805.    Because this output is behind a door it might be a cleaner looking set up to use the optical output on the top left looking at the back of the unit.  Because those two optical outputs are labeled "optical 3 and 4" they are zone outputs, they should work without having to "map" or patch them internally. The outputs here will be controlled independently as zones from the receiver's remote.      The easiest option looks to be the analog "pre output" located in the middle of the back of the receiver.  The left-most two rca jacks you want to use are labeled "front" and are white over red.  This output will work fine.  Control of the volume will be from the headphone unit and not the receiver.
Jan 07, 2009 | Audio Players & Recorders
Condition on HDMI input when Denon AVR-2807 switched off
hello if you know this spitter conduct voltage and its feed from main device and when you connect another it send it ground you have to do this chech with a voltmeter in the hdmi splitter output is not dc present if so change it cause is not blocking dc current saludos
Dec 04, 2008 | Denon AVR-2807 Receiver
Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Sep 28, 2008 | Denon AVR-2807 Receiver
What to use for Audio-out on Denon AVR-2807?
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Mar 15, 2008 | Denon AVR-2807 Receiver
Connecting wireless headphones
You should be able to get a cable with your headphone jack on one end and the standard left and right RCA jacks on the other end from just about any electronic store. Carl.
Sep 09, 2007 | Denon AVR-2807 Receiver
Denon AVR-2807 7.1 Channel Home Theater A/V Receiver Logo
184 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
