Question about Dell Inspiron 530s Desktop Computer
I can't get the power button to turn on computer
The button doesn't seem to be working is there another way to turn it on
  • 22 Answers
Is the button stuck? It could be a defaulted button. You may have to take it to a computer store to get it checked out.
Posted on Nov 29, 2012
  • Dell Master
  • 5,660 Answers
Yes Donna.
Uses the same method, as testing to see if the problem is the Power On switch, or the Power Supply.
Bypass the Power On switch.
Something I want to post before we go on;
The Power Supply in your computer is a converter.
Converts high voltage AC electricity, into low DC Voltages.
AC input power differs from country to country.
If I am correct;
Japan - 100 Volts AC (Depending on where in country)
US - 120 Volts AC
Europe - 240 Volts AC
Australia - 240 Volts AC
Converts into;
3.3 Volts, 5 Volts, and 12 Volts, and all DC Voltage.
In comparison two D cell flashlight batteries produce 3 Volts DC.
The Soft Power On circuit you will be dealing with, uses 5 Volts DC.
Dell Inspiron 530S motherboard illustration; no hardware, or cables attached,
http://www.dell.com/support/troubleshooting/us/en/19/Product/inspiron-530s
Click on Manuals & Documentation
Click on Owners Manual (12090KB)
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds before the first page comes up.
To go on;
In the Bookmarks menu to the left; click on the + sign next to -
Removing and installing parts
Now click right on - System Board Components
[ Zoom Out icon at top ( - ) reduces the view size, when you click on it. Zoom In icon ( + ) increases the view size ]
No.7 points to the connector on the motherboard, for the
24-pin ATX main power cable.
Here is a photo of the motherboard; Top View.
It is also turned 90 degrees to the Right; in comparison to how it is actually mounted in the computer case.
See the whitish rectangular connector at the bottom, that has 24 socket holes?
24-pin ATX main power cable connector, on the motherboard.
This is a general example of a 24-pin ATX main power cable; and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
View the photo to the right. Shows main power cable plugged in. This is what you want.
The GREEN wire is the Soft Power On wire.
ANY Black wire you see is a Ground wire.
Use a jumper wire to MOMENTARILY connect the Green wire, to ANY Black wire.
Does NOT involve cutting on any wire's insulation.
The preferred jumper wire is a paper clip.
The paper clip is straightened out, then bent into a U-shape.
The top of the U is wrapped a few times with black plastic electrical tape.
This taped area is for your fingers, and thumb to hold onto.
Turn the U upside down, and it is the 'legs' of the U-shaped jumper wire, that you are going to use.
The Back of the main power wire's connector, is where the wires go in.
One leg of the U-shaped jumper wire, goes down into the socket hole, with the Green wire in it.
RIGHT NEXT TO the Green wire.
Slides past the green insulation of the wire, and touches a metal terminal at the end of the wire. MUST touch that metal terminal.
[Metal terminal looks like this,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
Left side shows what the jumper wire will touch. The ends are crimped around the insulation of the wire.
The right side shows the opening, and Front of the metal terminal connector. The tips can be seen in the Middle photo, of the above playtool link ]
The other leg of the U-shaped jumper wire, goes down into ANY socket hole, that has a Black wire in it.
There MAY be a spark when the jumper wire makes connection.
Cautioning you in advance. You may wish to wear a glove, on the hand for the jumper wire.
The contact time is no more than 2 seconds.
The Power On switch is a Momentary Contact Switch.
Power Supply comes on you have a bad Power On switch.
Power Supply does NOT come on you have a bad Power Supply.
This ATX power on switch fits a LOT of computers.
http://www.directron.com/atxswitch.html
It will be located inside the plastic assembly, of the Power On Button. (IF it is the correct style. I'm guessing yes)
The Front Panel needs to be removed, in order to access the Power On switch,
http://support.dell.com/support/edocs/systems/insp530s/en/OM/HTML/parts.htm
Make note/s, and a drawing, as to where the Power On switch wires go.
Power On Button assembly removed, there may be a small screw, or screws to disassemble it; or just tabs formed from the plastic; of the Power On Button assembly.
I use a hair dryer to soften the aged plastic, and ease a tab, or two aside; to ease the Power On switch out.
Power Supply replacement procedures,
http://support.dell.com/support/edocs/systems/insp530s/en/OM/HTML/parts.htm#wp1484228
For additional questions please post in a Comment.
Regards,
joecoolvette
2 Suggested Answers
  • 4961 Answers
SOURCE: pc power button doesn't work
Get a psu tester like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16899705003
...and test the power supply to see if it's dead.
Posted on Jul 26, 2012
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
I have a acer travelmate 5740. When I turn it on the fan whirs for 5 secs then stops. The computer doesn't start and the screen remains black. I've tried holding the power on button for 60 secs as...
hello sir!
it seems that *********** borad or power board isn't working. just take it to some machenic he will repair it in about 20$ or less..
thank you.
Apr 18, 2012 | Acer Computers & Internet
Funny - didn't ask about a slide in electric kitchen range - was asking about my Jenn Air Stove. You deal with them, correct? Have a Jenn Air WW2780B that I can't seem to get working. It started...
I had a customer with the same problem last month and I believe it was on the same model as yours. Let me look in my database and I will get right back to you.
Warmest regards,Richard
Nov 01, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
Computer working perfectly fine one day, the next computer won't turn on for no apparent reason. when switching the power button on, computer begins to boot up for a brief moment, then automatically...
It's probably your logic board. One thing you can try that may help you out is to take out the battery (if you can) and press and hold the power button for 10 seconds. If it's a capacitor problem on the board that should discharge it. If that doesn't work then you should probably try to turn on the computer while holding CMD + Option + P + R to reset the PRAM. If that doesn't work then you're probably going to have to seek professional help.
Aug 04, 2011 | Apple Computers & Internet
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I have two Behringer Eurolive B415DSP speaker, one of them stopped working out of no where. To my best knowledge, the problem is that it doesn't turn on. I had the Fuse check already and thats not the...
This is alimentation fault of the amplifier inside the box. Dismount the amplifier block and take a look first if there are some burned pieces. If it seems all ok, better bring it to a electronics/ tv service center.
May 18, 2011 | Behringer Eurolive B415dsp 600w 15" PA...
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Dell Inspiron 530s Desktop Computer   Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
