Question about Samsung TXN2775HF 27" TV
Tv shuts down
Turn on with remote.After 20 min there is a bright flash in center of screen and tv shuts down.IN ABOUT AN HOUR CAN START TV WITH REMOTE.have had no problem for 5 yrs.
  • keymanreh Jan 10, 2009
    TXN2775HF HAS A CRT!
    WHICH CKT BOARD?AM AN EE BUT HAVE NO CKT DIAGRAM.THANKS
  • 10,594 Answers
Problem can be dry / cold solder joints in horizontal deflection area, specially near fly-back transformer.
Please look for cold/ dry solder joints on main board and you will notice them as solder on these joint does not look shiny. Resold them all if you have good soldering skills.
Posted on Jan 10, 2009
    Sergeant:
  • 378 Answers
Its the problem of power supply board of the tv it needs reparing or may be replacement.it needs to be checked.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, 2 of several possibilities:
  • horizontal collapse (least likely);
  • vertical collapse (most likely).
If a DIY (do-it-yourself) is ebing considered, this of course would require opening the unit, perform voltage measurements, determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY, perhaps your best bet would then be to seek the services of a qualified professional.
Pls post back result(s). Good luck and Thank you for using FixYa.
    Genius:
  • 1,239 Answers
HI There are reports that the power supply has dry o leaky capacitors. If you open the TV you will see the power supply # MLT169A.
I have fixed a few of this power supplies.
  • ABHISHEK.C
    ABHISHEK.C Jan 10, 2009
    the G board have also the problem. How many times per second does the POWER led blink? (dont worry about the OPC).
    1x per second (constant, steady blink) = bad inverter/lamps
    2x per second = bad power supply
    3x per second = bad main board
    You can buy the parts online and fix if yourself!!
  • ABHISHEK.C
    tV which turns on and flashes the Astar logo before the screen shuts down (Green power light stays on). From what i understand this is generally caused by low grade parts and to much heat. I dont know if you have gotten close to the TV while it is running but it gets extremely hot. The main issus with this is it causes the Capacitors to blow. there are about 20 of them and they generally sell for about $1.25 - $6 each online. If you have any experience soldering i have read about other people performing the fix themselves. I dont so i am currently looking into the cost to have them replaced by a professional. I will try and post what i find out.
    Genius:
  • 1,550 Answers
Did you check the fuse in tv ?
There is chance of loose connections and cold solder joints which are easily diagnosed by giving the set a whack with your hand .
    Sergeant:
    Novelist:
  • 326 Answers
Its the problem of the internal circuit components getting overheated and the tv going shut off.that board has to be checked with a meter and the faulty component should be replaced.
  • Samsung Master
  • 19,396 Answers
That is a problem with the power supply board or a bad deflection yoke, this if the tv is a CRT.
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Tcl tv screen
hi go into the menu on your tv scroll to picture setting turn the brightness down also look for bl which means back light set it to about 10 hope it helps
regards
shaun
Jan 25, 2014 | Televison & Video
My remote stopped working and my tv is stuck on video 2. Is there a way to get it back to a regular screen without the remote? when i go to the menu button it only allows me to change the language or the...
There should be a button on the TV "INPUT" press to change sources. It should be on the front lower center of TV, slide panel to expose if required. Put new batteries in remote.
Aug 21, 2010 | Sanyo DS20930 20" TV
Tv turn it off and turn it on every 20 min
put tv into standby and press INFO / MENU / MUTE / STANDBY on remote you have to be quick
the tv will come on with factory settings on screen
ONLY USE DOWN NAVIGATION KEY move to reset and press RIGHT NAVIGATION KEY press standby to exit
tv will come on and will need retune
if this not help then will be capactors on mains power board failing look at them and if any have raised tops replace then
Dec 15, 2009 | Samsung HP-T4264 42 in. Plasma HDTV
My sony kf we50s1 switchez off at certain times on its own we lost the manual an its only 5 yrs old....it will switch off an hold for about 5mins den u can turn it back on using remote sumtimes it will...
Sounds TV needs new lamp because existing lamp becomes weak in result and causing TV shut down.
Did you replaced its lamp recently?
Lamp replacement procedure would be written in user manual of TV.
Oct 28, 2009 | Sony Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Nov 09, 2008 | Samsung HL-T5687S Television
Tv loses power
the processor on this et will shut this set down for number of reasons. a technician should be albel to read error codes form the processor to help deterine whatt is cause the shutdown
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Samsung TXN2775HF 27" TV Logo
Henry  Thomas
Henry Thomas
