Question about Hoover Nextra HNL 3166 Z Front Load Washer
My HNL 7166 hoover washing machine nexus won't drain
I washed a rag rug which was heavier when wet than anticipated and also shed lots of bits of rug. Now my machine won't drain. Any ideas as to how I can drain it. We've opened the inspection hole at the front but water pours out and it is in an upstairs bathroom at the moment as we are living on a building site. Also why won't it drain - could something be lodged in it somewhere? PLease help!
Sara
ngfam1
  • 639 Answers
SOURCE: hoover optima hnl 7166
I'm Neil, Glad to be of assistance for you!
Sounds like you need service.
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Posted on Aug 24, 2008
  • 1122 Answers
SOURCE: Flashing stop light
have you tryed unplugging it for 5 minutes to see if it resets itself?let me know-mike
Posted on Oct 31, 2008
beltronic205
  • 1474 Answers
SOURCE: the conditioner compartment is always full of
It should clip off , hold down mid lever and pull out you should be able to see the lever...
Posted on Apr 08, 2010
  • 353 Answers
SOURCE: Hover washing machine model HNL 7166. The bright
could be a sign the bearing seal has gone u need to replace the bearings
Posted on Jun 29, 2010
Testimonial: "Thank you for the information. I will look into this and see if it helps.."
  • 6277 Answers
SOURCE: hoover model hnl 7166 door remains locked at end
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 27, 2011
Machine won't drain
You will find that the pump is blocked, you need to attempt to remove as much of the water as possible and as rugs are not the best thing to wash in a washing machine they tend to shed a lot and get the bits stuck in the pump. You may have to completely remove the pump from the machine in order to completely clean it.
Mar 07, 2012 | Haier Washing Machines
Hoover model hnl 7166 door remains locked at end of cycle how do i open it
John C
Sep 27, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
HNL 3146 WILL NOT EMPTY AT END OF WASH
Hi davebmail,
It could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Flashing stop light
Oct 31, 2008 | Hoover Washing Machines
Hoover optima hnl 7166
Try :
A&E Factory Service
1-800-905-9505
Good work
Thank You
Neil
Aug 24, 2008 | Hoover Washing Machines
Not got user manual for hoover hnl7166
Click on Hoover (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 13, 2008 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover Nextra HNL 3166 Z Front Load Washer Logo
446 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
