Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Dishwasher does not run
The display is showing horizontal orange lines. While the dishwasher will not run or will run and not shut off even with the door open. After leaving it off for a 10 min period it will work fine
Hobart AM 15
  • 640 Answers
I'm a hobart tech and repair these units often.I can tell you this---If you open up the control panel and see water the wash tank has a crack in it.If this is the case depending on the serial number you may be able to get a new dishwasher.What happens is the water gets onto the electronics and shorts out.What is the exact serial number,model number and ml number?How old is it and where are you located?Have you had any repairs done by hobart or any other service company?
Posted on Jan 25, 2009
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Bosch dishwasher SHU66C02UC
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 22, 2008 | Bosch SGV56A13 Built-in Dishwasher
MACHINE WILL NOT FILL, HOW DO i CHANGE INLET VALVE
most inlet valves are near the front of the washer. The kick panel at the front of the dishwasher should have several screws holding it, take those out ant the kick plate should come off where you can get to the valve. Look under the sink cabinet and you should see two vertical water lines and one horizontal line. The one horizontal line runs through the side of the cabinet to the dishwasher it should have a shut off valve on it close the valve and that will cut off the water going to the dishwasher. Have several towels ready because there will be water left in the line. Either unplug the dishwasher or turn off the breaker for the dishwasher before working on the valve Place a towel around the area of the inlet valve and disconnect the line coming to the valve. Should be a couple of screws holding the valve to the washer. Disconnect the electrical connections and remember where they go. Take valve out and reverse the procedure for installation.
Jan 07, 2010 | Beko 24 in. D3421F Free-standing...
Two horizontal dashed line and won't start
A dishwasher operates in a hostile environment. Eventually the corrosive soap can damage the electrics & the electronics. If you have the skills, I suggest you turn off the breakler to the diswasher, then dissassemble the console & control board. Spray the contacts with WD40, & reassemble. The very sliding-action of dissassembly/reassembly should cure any contact issues. I hope that this helps.
Jul 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
I've moved to another home and would like to re-connect my dishwasher. I am new to this & need to tap into the hot water line from the sink. HELP! How do I run the water line in an L configuration and then...
If you new home doesn't already have a branch line for a dishwaher, I'd get a plumber to install a copper T on the existing line then a second shut-off valve for the dishwasher. If there is ever a problem with the dishwasher, you can shut off its water supply without intrupting the sink water.
Mar 21, 2009 | Kenmore 24 in. 16182 / 16189 Built-in...
Water continues to run, even when unplugged....
Hi, had the same problem. Water would not stop entering the dishwasher until the water valve for dishwasher was completely shut off. (Even when circuit breaker for dishwasher was turned off, the water still came into the dishwasher). Well after research, it is the water inlet valve. Replaced it yesterday and it is working as good as new. Look up this part online if you aren't sure what it looks like. Good luck,
Jan 08, 2008 | GE 24 in. Profile PDW7880G Built-in...
Dishwasher short cycles and shots off
batty, you can put the dishwasher in a automatic test mode or manual test mode. For automatic press the heavy wash key 5 times followed by the start key. 88 should show in the display if you have the digital display. It's going to check the wash motor, fill valve, drain motor, soap dispenser, vent and heater automatically. If any of these systems fail, you will get a code. The test will finish by itself. You can get the information to test the touch panel by getting the tech sheet from behind the bottom toe panel. Catriver..post back.
Jan 11, 2007 | Maytag 24 in. MDB7600A Jetclean® II...
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
244 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
