Question about Nikon COOLPIX P90 Digital Camera
My Nikon P90's memory card is write protected...How do I change this to delete images?
I want to delete images from my memory card on my Nikon P90 but it won't let me as says the card is write protected.....How do I change this so I can delete?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Nov 28, 2012
  • kakima Nov 28, 2012
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
  • 415 Answers
SOURCE: Cannot remove memory card write protection Nikon Coolpixs9
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
Posted on Feb 13, 2009
fblock
  • 289 Answers
SOURCE: memory card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Posted on Apr 27, 2009
  • 33 Answers
SOURCE: The camera says Memory card is write protected and
If it is an SD memory card, check for a little white tab on the left side. Chances are that somehow it got pushed down to the 'write protect' mode. Move it back up and you should be good to go! Good luck.
Posted on Aug 05, 2009
  • 102366 Answers
SOURCE: "memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
I have a nikon coolpix. It is continuously showing 'MEMORY CARD IS WRITE PROTECTED'. I cannot take any photos. Please help.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 17, 2012 | Nikon Coolpix S50 7.2 Mp 3x Optical Zoom...
Hello, I have a Nikon L11 digital camera and i can't delete my memory card...it says memory card is write protected...what can i do to delete all pictures
Hi Look at your memory card! You may have accidently caught the small slider on the card that has locked the card, Just unlock it will be fine! Hope this helps!
May 21, 2011 | Nikon Coolpix L11 Digital Camera
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
I accidentally protected a picture on my camera nikon d60, how to unprotect it and delete it
There are 2 ways to do it. Firstly you can format the card - this will delete all images, including protected ones. Second method is to display the image in full frame view mode (or highlight it in thumbnail view) and then press the AE-L /AF-L button. This will remove the protection - or protect an unprotected image.
Hope that helps
Aug 01, 2010 | Nikon Cameras
I downloaded some pictures to my school computer and now my camera won't take any pictures. Message is Memory card write protected.
If that doesn't work, try another card.
Feb 26, 2010 | Nikon Coolpix 4500 Digital Camera
My camera tells me it's out of memory. What do I do about clearing that up so I can use the camera. Also, there's a message thaat my memory card is write protected. How can I clear this up?? I own a...
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. Clear Memory: To clear it, first make sure all of your images are off of it (on your computer) and then use the camera to "format" the memory card. Formatting the card erases ALL OF YOUR IMAGES - so be sure you've got them saved! This function will delete anything on the memory card and give you all the space available.
Apr 27, 2009 | Nikon Cameras
Solution 1 Card has a protection tab, it could be in the locked position, try moving it. then try in camera.
Solution 2 use a progran like Image Rescue, downloadable from www.lexamedia.com to save images & then re format card
Mar 01, 2009 | Nikon Coolpix 4500 Digital Camera
Feb 12, 2009 | Nikon Cameras
Nov 10, 2008 | Nikon Coolpix L11 Digital Camera
Nikon COOLPIX P90 Digital Camera Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
