Question about Element Electronics HD LCD TV ELDFT404-B
How do i attach the tv stand to the eldft404 element tv?
The holes dont seem to match up properly
When replacing a automatic transaxle on 2006 Mazda how do I match up torque converter to the driveplate?
it will only line up one way ,so try by putting in one bolt then rotate converter and flex plate if the next hole lines up put a bolt in it DONT TORQUE ANY TILL ALL ARE IN . if the holes don't match up take out bolt and rotate flex plate by one bolt hole and so on till you find the right bolt pattern then bring in all bolts then torque them .Good luck Woody
Jun 10, 2015 | 2006 Mazda 3
How to get rid of Dac8008ee light stench?
If you checked outside and it's not draining properly, try sticking wire with a pipe cleaner attached through pipe. Make sure wire is flexible enough to go through pipe and make sure pipe cleaner is secured. Or just try to blow compresed air through line.
Jun 11, 2014 | Danby DAC8008EE BASE PAN - DB90-01255B
How do you change door swing direction?
Refrigerators with reversible doors have mounting holes that are plugged on the opposite side. You have to remove the plug(s), remove the door and its hardware, position the door hardware to match the exposed holes and install the door with the opposite swing. Careful attention must be paid to proper door alignment so that it closes properly and seals properly.
Jun 03, 2014 | Roper Refrigerators
Thermador dual fuel oven temperature not accurate and the dials dont match temperature
Faulty thermostat it's the thin copper shaft in the oven that has a skinny tube running from it if you remove the oven knob you will find it goes back to the switch. Needs replacing.
Apr 21, 2014 | Thermador P304CS Gas Kitchen Range
Dont know which hole to plug my speakers in my pc
Check your holes the GREEN JACK hole is for speakers, there should be a symbol next to it matching the same on the speaker's jack...
Aug 29, 2010 | Packard Bell Speaker Computer Speakers
Hi.my a4's overheating and seemingly no oil pressure.
well you may have put the gasket back on wrong blocking the oil hole which supplies the oil to the head, this would cause the low oil pressure and the oil light coming on.
If the gasket is on the wrong way it may be causing the overheating problem as well by blocking or partially blocking the water holes in the head that allow the water to get to the head and cool it down.
these are the only things I can think of apart from maybe a cracked block caused by the overheating but that would not explain the lack of oil to the rockers
Hope this helps
Jun 14, 2010 | 2002 Audi A4
My computer won't start up
it seems like you my have replaced it with the incorrect power supply unit i would check to make sure that they were matching if they dont then you will need to get a new one that matches the old one this is a commen mistake once you have the right one it will boot up properly no problem at all you will not loss any datab hope this helps
Mar 14, 2010 | Northgate (STAX2517C2) PC Desktop
Headlamp loose on drivers side. seems to go in and out when driving. the light still works but is very dim. Have plugged the wires in, but they loosen right away. Is it the headlamp bulb or assembly. This...
If it is the light bulb, meaning the replaceable glass bulb that gets plugged by the wire connector, the clip may not be properly seated on the housing of the bulb. Take the time to match up the tangs of the bulb housing to the hole it plugs in to.
Oct 25, 2009 | 2002 Ford Escape
2001 f250 diesel
Had the same problem on my 2001 Super Duty.
Solution: leaking vaccume line to the auto locking hubs. It seems Ford saw fit to tie the two systems together. Once I fixed the lines to the hubs my vents worked properly.
Jun 05, 2008 | 2001 Ford F250 Super Duty Super Cab
Element Electronics HD LCD TV ELDFT404-B Logo
53 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
