Picture won't show the screen says channel unavailable it's a sharp flat screen tv
  • 57 Answers
If the channel is unavailable,its unavailable in the package that you have or ordered.Some companies that supply the packages,switch the movies,or ch. numbers for others..another words if it was in your pkg. they might have added another one and deleted the one that is now unavailable..Recently some companies like Direct bunched all the channels that you get,together,instead of scattered through out the tons of numbers..Or they ripped you...Call the company up you deal with,they can tell you exactly what they did...Don't forget press 1 for English...
Posted on Nov 28, 2012
  • 298 Answers
SOURCE: VGA to SHARP flat sreen tv
1. vga to vga cable
2. vga to dvi cable
3. vga to dvi cable, then dvi to component cable
Your tv must have 1 of the following:
- vga connector
- dvi connector
- component connector
Posted on Feb 25, 2008
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
SOURCE: no picture - 65535 shows on screen
i haven't tried unplugging my 19 " Dynex (Model: DX-LCDTV19)...yet, hopefully i won't have to. but, i did run into the 65535 ÿÿÿ... thing, except my screen actually read "65535 ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ bad" and i was not able to change the channel. the "air" option under the "Air/Cable" option under the "Channel" heading of the "Menu" -phew!- did yield me about 20 channels; but it was not the ****-near hundred channels i'm used too, ****! so i did do a cable-channel-channel-scan, as forementioned by the illustrious mr/mrs Dynex100 him/herself in the post immediately prior to this one! and this fancy technique reunited me with my beautiful cable- and it feels so good! much like a mother kitten refinding her unlost baby kitten. furthermore, the "65535 ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ bad" went away...for the most part. now my screen looked as it normally would, but still read "ÿÿÿÿÿ"<--- to a much less extent, as you can plainly see, yet still obtrusive! so i powered off, waited impatiently for about three seconds, and then slapped the ole **** tube right back on. the weak and merciful "ÿÿÿÿÿ" blip had miraculously vanished into thin-digital-cable-air! i then went on to taunt the puny-little circumvented "ÿÿÿÿÿ" blip by literally programming the sleep timer to do its thing in precisely 5 mins. the 5 mins. ticked away, and my radiation king 5000 turned off on cue. without hesitation, i lept from my wheelchair and brought power back into my 19" Dynex (Model: DX-LCDTV19) by putting it into "On" mode. this exact sequence of crazy manuvers must have really intimidated the "ÿÿÿÿÿ" blip, 'cuz he ain't been 'round since! hope this helps someone.........................................somewhere.
Posted on Feb 17, 2009
roety
  • 585 Answers
SOURCE: My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Posted on Aug 16, 2009
milkburp
  • 416 Answers
SOURCE: Flat screen tv power surged
Is it just the cable? Do you have a DVD player or game system connected? If so, how do they look? Ofter a momentary power loss can cause cableboxes to loss picture, loss sound, and even cause the picture to be distorted. Try unpluggind the AC power from the cablebox and TV. Wait about 5 minutes and reconnect both. Leave the cablebox alone for about another 5 minute after you reconnect it so that it can fully boot up. Then see if you still have the problem.
Posted on Mar 15, 2010
Sharp tv won't display cable picture (it only shows fuzz) but the netflix and DVD both work. The cable says no input service available. I am able to change the channel on the cable box, but on the tv
Your cable box might not be sending signal out to the tv. Would have to call service provider to have them test your box. Or, you can try unplugging your cable box, and then plugging it back in. Make sure all connections are secure and settings on your tv are accurate. 11_13_2013_3_31_52_pm.png
Aug 11, 2013 | Televison & Video
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
Sharp LC37D44U Power LED was flashing green. TV would turn on, channel indicator shows in upper right corner, sound good, but screen would be black. Channel indicator disappears but screen is still...
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Nov 16, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
Apr 29, 2009 | Sharp Aquos LC-32D40U Television
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Size of screen
If you have black panel os sides the picture is not HD. Not allways the HD broadcasting have HD shows. The advertising for example is not HD. Check the picture size in the tv to be "allonged" and play with the screen size with your cable box remote. Usually is # button.
From what I know LC42D62U has no TV Guide feature.
Dec 06, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
