Question about Casablanca Fan Dryers
INTELLI TOUCH FAN, FAN WILL NOT COME ON UNLESS LIGHT IS ON FIRST
If the light is off and I hit the fan button, you hear the fan direction changing but does not come on. If I turn the light on first, than I can turn on the fan. This is an intelli touch fan with a wall switch
3 Suggested Answers
SOURCE: It seems that we need a pc board for our intelli
Thank you, but I already found a web site that sells the conversion kit to update the fan.
I understand that the original parts are no longer made and it is recommended to convert.
Thank you!
Posted on Jul 18, 2009
SOURCE: I have a Casablanca Intelli touch ceiling fan.
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Posted on Sep 01, 2010
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Jul 20, 2010 | Casablanca Fan (3232A) Ceiling
I have a Casablanca Intelli touch ceiling fan. The remote is a simple toggle switch, turn in on, listen to the beeps, off an on quickly to set it. How do I reverse direction on this fan?
Apr 01, 2010 | Casablanca Fan 3245T Ceiling
Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
New Hampton Bay Ceiling fan - runs only in clockwise direction
By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
Jan 17, 2009 | Hampton Bay 24002 Ceiling Fan
Reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Nov 20, 2008 | Hampton Bay 52 In. White Redington...
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Dryers Logo
35 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
