Question about Xerox Phaser 7760 Laser Printer
Reset accumulator belt life Phaser 7760 - Xerox Phaser 7760 Laser Printer
  • 18 Answers
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
xptareq2000
  • 1447 Answers
SOURCE: Phaser 7760 - RAM ERROR
yes often your printer Ram or reset then solve it
Posted on Jun 26, 2009
  • 2072 Answers
SOURCE: how do i replace an accumulator belt on a Phaser
  1. Open the Front Cover.
  2. Release and move the IBT Cam Lever down.
  3. Open the Right Side Door.
  4. Removing the IBT Belt Assembly
  5. Lift the Accumulator Belt Locking Level and pull the Assembly out to remove.
  6. Use Handle to transport IBT Unit. Protect the IBT Belt Assembly from
  7. On the front, there will be 2 torx screws on a plastic strip. Remove those and the cleaning assembly.
  8. There are 2 spring loaded clips. One on front and one on back that release the spring tension on the roller. You have to press them in and press the locking tabs.
  9. Then go around the frame and remove the screws in order to "fold" the assembly and remove the belt.
  10. Be very careful not to bend the bracket near the bearings or you will have belt tracking faults after replacement.
  11. Be sure you install the belt in the correct direction. There is a silver patch on the belt that must be on the inside of the belt assembly when installing. Look at the old one before removing to determine the orientation of the belt.
Posted on Jan 14, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
The accumulator belt on my 7760 phaser is giving a past end of life message. How can I find out how many copies it has remaining?
Try printing the full status sheet. If you print out all the setting it should cover all the information you need to make your judgement.
Good luck.
Mar 26, 2015 | Xerox Phaser 7760 Laser Printer
How to reset the fuser xerox 7760
NVM setting
  • 744-354 (Fuser Warning Point). Set it to 490.
  • 744-355 (Fuser Life Point). Set it to 500
Sep 15, 2014 | Xerox Phaser 7760/GX Laser Printer
Reset phaser 7760
Hi Anonymous,
Due to the fact you asked for help quite some time ago I suspect this problem might be sorted by now.
If not use the www.Xerox.com website should be able to help.
Regards.
Jul 03, 2014 | Xerox Phaser 7760 Laser Printer
Accumulator belt for Xerox Phaser 7760: can I refurbish this unit myself? If so where can I buy the parts to refurb the belt?
064K91451 iteminconline they sell the belt only and also the home position sensor encase you have an error.
May 12, 2014 | Xerox Phaser 7760/YDX Laser Printer
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
How do i replace an accumulator belt on a Phaser 7760
Jan 13, 2010 | Xerox Phaser 7760 Laser Printer
Hello i hope someone can help me with my problem i need reset the fuser uit xerox phaser 7760,because the rollers both(up,low) are like new condition thank you
You can get more life out of the fuser by removing one end and placing a piece of tin foil OVER the THREE FUSES, which are designed to blow at set times. Just tape it in place with some tape.
Good Luck
Oct 03, 2009 | Xerox Phaser 7760/YDX Laser Printer
Xerox printer error
The answer can be found here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
You must manually reset the Belt Cleaner life after replacing the belt cleaner.
Resetting Belt Cleaner Life
  • Resetting the belt cleaner life is to be performed only if the Belt Cleaner Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Belt Cleaner Assembly or Replace Belt Cleaner Assembly Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Belt Cleaner Assembly is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Belt Cleaner life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, then power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Belt Cleaner life if the printer didn't prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Belt Cleaner Life
  6. .
  7. Press OK.
  8. Reset Belt Cleaner Life NOW is displayed.
  9. Press OK to reset the belt cleaner life.
Mar 08, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7760 Laser Printer Logo
215 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
