Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Element FLX 3210 not scanning for cable channels
I have an Element FLX 3210 LCD TV. Just got cable connected yesterday and when installer hooked up cable to the TV it will not pick up any channels. The cable outlet works for sure because we connected another TV and everything was fine. The TV pictures is ok because it works just fine with the DVD player. But when I try to program (scan) for the cable channels, it doesn't pick any channels up and just goes back to the blue screen and says "No Signal". The cable installer thinks maybe the plug in for the cable on the back of the TV may be bad? If so, is there any way around that? Oh and it also will not work if we hook up cable through the VCR first and then run it into theTV either. THANKS for any help - I'm so frustrated.
  • 29 Answers
YOU HAVE A BAD TUNER OR RF INPUT. IF YOU CONNECT THE CABLE TO THE VCR AND THEN USE THE VIDEO OUTPUT OF THE VCR TO THE VIDEO INPUT OF THE TV YOU CAN USE THE TUNER IN THE VCR TO CHANGE CHANNELS.
Posted on Jan 12, 2009
After scanning channels tv still does not have picture or sound
What type of input and what type of cable have you set to ?
(a) Antenna - Coax cable (75 ohm)
(b) STB - HDMI
(c) DVD - HDMI or
(d) DVD - Red+White+Yellow
(e) DVD - Red+White+Optical (if your TV and DVD support it)
Most TV cannot find any channel when scanned without a proper external /internal antenna
Aug 11, 2016 | Element Electronics FLX-3211B 32 in. LCD...
I lost the power cord during a move to my FLX-3210 Element TV. I can not find it anywhere. Help!
It is the same power cord as used for your PC. One end is NEMA5-15P, anther end is IEC C13.
RadioShack or local PC repair shop should have them.
Jul 11, 2011 | Element Electronics FLX3210 32 in. LCD TV
I have an Element FLX 3210 that won't light up and show a picture..it has the sound but no picture.
Check the two caps (10uF 450Vdc) by the inverter transformers, also check fuse F2.
Worst case will be shorted out ballast caps in the LCD panel assembly.
http://s807.photobucket.com/albums/yy352/budm/Element/Element%20FLX-3210/
Jun 04, 2011 | Element Electronics FLX3210 32 in. LCD TV
When I tried to hook my FLX 3210 up to my computer it failed to turn on at all. I used this same LCD T.V. with my old Acer Computer and had no problems at all.
you may be having a power supply failure. i have seen many problems with capacitors on the power board in those models. are there any lights on the front when it doesnt turn on? if it were a power supply problem then you would maybe get a red light or blue light come on then go back off,
Jan 06, 2011 | Element Electronics FLX3210 32 in. LCD TV
I just lost all my digital channels. The problem started yesterday and continued today. When I changed to a channel the TV would give off a load crackle sound and the picture and sound would disappear....
this is what i can tell you your tv has 2 boards a main one and a power supply one anything that has to do with your imputs tv, av, hdmi, etc has to do the main that includes the picture going off and sound you can contact the manufacturer and tv technicians, but the only place that its going to be cheap its at www.shopjimmy.com guaranteed
Apr 13, 2010 | Element Electronics FLX-2610 26 in. LCD...
Blurry picture when hooked up to direct tv.Why?
try lowering the sharpness on your tv, because if the sharpness is to high it will make NonHD objects look blurry, also try changing the input cable or type of input.
May 20, 2009 | Element Electronics FLX-2610 26 in. LCD...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
1,475 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
