Question about Hardware & Accessories
Paragon EC 4004 Manual - Hardware & Accessories
5 Suggested Answers
  • 52 Answers
SOURCE: Need trippers for Paragon #4004-20
send inquiry to electricalexpeditors.com
we sell replacement parts
Posted on Feb 02, 2010
SOURCE: I have a AMF Paragon
Open following link to identify Paragon 4004 240Volt timer, download manual, see typical wiring, and see instruction illustration.
ttp://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Posted on Jul 19, 2011
  • 52 Answers
SOURCE: i have a amf paragon model 4004-20 time switch
check the uniline website
Posted on Feb 26, 2010
SOURCE: i have a paragon timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Posted on Nov 23, 2010
Ec 71 st
EC71 series manual appears on link above.
paragon EC series is defunct and I do not have resources that differentiate the various suffix endings to model numbers
gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 05, 2014 | Paragon Hardware & Accessories
Need a manual for paragon timer EC 74/120D
Try Googling (paragon)(EC 74/120D)(manual) without parens.
Nov 11, 2013 | Paragon 4001-00 24-hr Timer Control 120v...
The clock on my paragon 4004-71m is not working
1) Clock motor has gone bad, but replacement clock motors are no longer made.
Copy following link for Paragon resources:
2) Paragon is not making parts or replacement motors.
4007-41 is 240Volt timer, replace timer with Intermatic T104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
3) Crossover wiring from Paragon 4004-71 to Intermatic T104:
Paragon 1 to Intermatic 1
Paragon 2 to Intermatic 2
Paragon 3 to Intermatic 4
Paragon 4 to Intermatic 3
Intermatic terminal A is generally not used for 240Volt
4) Add a comment if needed
Jan 17, 2013 | Paragon Hardware & Accessories
I want to replace a Paragon 4004 20M with a Intermatic T104M. The Paragon has 4 screws along the bottom and one more on each side higher up for a total of six. The Intermatic has six, plus the ground. ...
1) These timers are interchangeable.
2) These timers can be complicated. Both handle multiple voltages and can be wired many ways depending on load requirement, wire from breaker box.
3) Description of Load(s), voltage(s) and wiring is not described in question. Add a comment with specific information for detailed help.
4) The 4004-20 timer has wiring terminals 1 2 3 4, plus terminals 5 and 6 that are connected with a brass bridge to terminals 1 and 4.
Since the terminals are connected with brass bridge, terminals 5 and 6 can be considered same as terminals 1 and 2.
If the brass bridge is removed, then the timer can be wired many ways to control multiple voltages, and then terminals 5 and 6 are independent.
5) Intermatic T104 timer has terminals A 1 2 3 4
Intermatic T104 terminal A is not used except as a bare post for Neutral wire, and if timer is wired to control 277V or 440Volts. Or if timer is adapted in other manner.
6) When controlling ordinary 2-wire 240Volt load like a pool pump, here is crossover wiring.
Paragon terminal 1and5-bridged goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminal 3 goes to Intermatic terminal 4
Paragon terminal 4and6-bridged goes to Intermatic terminal 3
Intermatic terminal A is not used in this case.
Sep 13, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
I need trippers for parogon elect timer model # 4004-20
1) Paragon is no longer making timers or parts except defrost timers.
4004-20 240V 24-hour mechanical timer is not a defrost timer.
2) paragon 4000 series uses X2772 tripper.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
3) Some sites still show the X2772 tripper.
Some sellers are seriously overcharging for the tripper.
4) If you want to buy new timer: Intermatic cross-reference guide shows T-104 240V 24 hour is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
5) Amazon sells new T104 for 50$ which is cheaper than some folks are selling the paragon tripper:
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/tags-on-product/B000BQOX88
6) Change-over wiring from Paragon 4004-20 to T-104:
Hot wires from breakers. Paragon terminals 1 and 4. Intermatic terminals 1 and 3
Load wires. Paragon terminals 2 and 3. Intermatic terminals 2 and 4.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 08, 2011 | Hardware & Accessories
I need a replacement mechanism for a Paragon 24 Hr timer control Model 4004-71M.
1) Paragon is no longer making timers and parts except defrost timers.
4004-71M is not defrost timer.
2) Manual shows 4004-71M is DPST 40 amp 240Volt timer.
4000 series is 24 hour repeat timer
3) To buy replacement timer, Intermatic crossover guide shows T104M used for pool and spa controls and to replace timer mechanism
T104M at amazon
http://www.amazon.com/Intermatic-T104M-Mechanical-Mechanism-208-277/dp/B001DNYMV6
4) Or you can buy T104 with Nema1 indoor box, or T104R with Nema3R outdoor box
Googel search model number for vendor
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
5) How to wire T-104
For a price, fixya expert speaks with you over phone while you work on timer or any
Jan 07, 2011 | Paragon Vintage 24 Hour Timer Command 12...
Have a paragon amf 4004-71 timer it runs constantly
Paragon 4004-71 is 240Volt timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
1) If your trippers are worn down, the timer will not turn on and off
Google search for X2772 trippers.
2) If your timer dial is not rotating, then timer clock motor is bad.
3) According to e-mail I received from Paragon Nov 2010, Paragon is no longer making timers and parts, except for their line of defrost timers.
4004-71 is not a defrost timer, so it is no longer being made according to Paragon representative.
4) To change timer brands: Intermatic cross reference shows Paragon 4004-71 can be replaced with Intermatic T-104 timer.
Intermatic cross reference link:
Lowes and Grainger and many other outlet sell T-104 240V timer.
Dec 15, 2010 | Woods Outdoor Photoelectric 24 Hour...
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
Aug 21, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
Need instrutions manual for the EC 4005 timer
The link below will take you to the EC4000 series Paragon manual.
http://www.paragontimecontrols.com/manuals/paragon/110-668B.pdf
This link will take you to EC4000 series cut sheet that shows specifications and wiring diagrams.
http://www.paragontimecontrols.com/SellSheets/Paragon/EC4000%20Series.pdf
Apr 12, 2010 | Paragon Hardware & Accessories
Hardware & Accessories Logo
932 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
