Question about Gateway 835GM (835GH) PC Desktop
Installing SATA optical drives on a Gateway 835GM Pc with an Intel [Big Lake] 945G Motherboard.
Waynerd: I'm waiting for you're answer to my last question, to recap:
Thank you and all the other Fix Ya members for their assistance thus far.
Please be advised that I installed the G.Skill 2GB [1X2GB] without any problems.
I need your help with the following issues:
Before installing the SATA optical drives should I uninstall both IDE drives from the device manager?
Should I set the SATA controller to automatic in the BIOS before I begin to install the SATA optical drives?
My Intel 945G only has the hard drive installed in the SATA connectors. Its installed on the furthest right side connector. Refer to the picture of the motherboard you sent me.
Can I install the drives in any order on the controllers, or is there a specific path to follow?
Once properly installed do I have to download any drivers for drives, or will windows automatcally find them?
Can I leave the drives on the CS setting, or do I need to set master and slave?
Once again, waynerd, and all the others, thank you for taking your personal time to assist me with my problem.
My sincere thanks,
Enrico
  • enrico49 Jan 10, 2009
    waynerd: Once again, thank you for your time and help.
    Thanks,
    Enrico
    President:
  • 1,901 Answers
Enrico,
I would just physically remove the drives and the connecting cable(s) and reboot your computer. Look in the device manager and make sure they are gone. They should be gone, but if not, you can then remove them from it.
There is no certain slot to install the new drives, just use the next 2 slots. You can set the SATA Bios setting anytime. I think most defaults are set to Auto anyway.
I would leave the jumpers on CS.
As far as drivers, I would assume there will be software with drivers enclosed with the new drives. Windows will recognize the new drives, and when it asks about drivers, there should be a "Have Disk" selection if you get a CD with the drive. (If no CD, have it install/search for the best drivers.)
There will no doubt be installation instructions enclosed with the new hardware too. Read it thoroughly. It may answer much of what you ask here. Good luck.
Posted on Jan 10, 2009
Where can i get a free diagram of the motherboard layout for the Gateway 835GM?
There are many things to be considered by having a problem with your boot up. First common factor is infected with the virus of your operating system or corrupted, then possible your hard disk drive is having a mechanical trouble due to improper shut down or by hanging up. If this is the case, you have to reformat your computer operating system and or change you hard disk drive in order to fix the said problem.
Jun 01, 2014 | Gateway 838GM (RB838GM) PC Desktop
How to connect a cd rom/dvd
If your CD / DVD is powered on Ok then you are missing the data cable connection which will be either a SATA (small connector) or IDE (much larger connector) both of which plug in to your motherboard....Look at the CD / DVD and try to identify which type of connector you are missing then look for an unconnected cable of the same type within your case.
Dec 17, 2011 | Gateway LX6820-01 Desktop PC
What motherboard can i upgrade to from the 836GM Media Center PentiumD 820 Dual-Core 2.8GHz
You can upgrade your system using most any motherboard, but note that the motherboard must match the CPU you are thinking about using.If you have a proprietorial computer (like a Dell or Gateway) the motherboard might not fit without a case modification.My advice is to figure out what your needs are. Research the CPU you wish to use and then find a motherboard that supports it.
Oct 16, 2011 | Gateway 836GM Media Center PentiumD 820...
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
Processor upgrade
You have a P4 Processor.... a 3.0 was the fastest. I would not upgrade the processor. You can however upgrade the Motherboard if you can do it yourself. That will take you to a SATA Hard Drive system and allow you to afford some faster RAM and Cheeper RAM.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138079
Another option: get 1 gig of ram, new Hard Drive and Win7. Speed improvement will be double.
Dec 27, 2009 | Gateway 835GM (835GH) PC Desktop
Can't find a manual for Gateway GT5428 motherboard
I believe that is a pci express slot (x1)
Here is the manual for your motherboard:
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Jun 28, 2009 | Gateway GT5428 PC Desktop
I Tried to ddownload Sigmatel HD Audio Driver Version 6.10.0.5274 the Response was:device object not present My CPU Processor: 2.8GHz Pentium D 820 Memory: 1GB DDR2 Storage: 250GB hard drive Optical D
Hmm.. interesting,
Checked the typical settings
- Volume control settings are normal (Sound on/not muted)
- Device Manager can detect a sound driver ~ if not, install it
- Driver File did not download correctly ~ try re-downloading the file
- If using audio jacks (usually known as the "green" cable), make sure that they are working properly
If this didn't solve the problem, reply to me thanx.
- donman92
May 31, 2009 | Gateway Computers & Internet
CD/DVD Burners for Gateway 835GM PC
Your system has 4 SATA controllers which I mentioned on your previous question. Yes, they will work.
SATA drives are faster than the IDE interface drives.
Here is your motherboard:
The SATA connectors are those 4 approx. 1" vertical black connectors about a 3rd of the way down. The IDE connector is the horizontal one right on top of them.
As long as the SATA controller is set to Automatic in the BIOS, you should not have any problems. Also, the new drive should come with a SATA cable.
Jan 08, 2009 | Gateway 835GM (835GH) PC Desktop
Install more memory, install new dvd/cd drives
As far as the memory in your system goes, each memory slot can hold DDR2 PC2-8500, DDR2 PC2-5300, or DDR2 PC2-6400 with a maximum of 1GB per slot. You can add two 1GB modules to your present configuration if you choose.
For complete info go to: Crucial for Gateway 835GM
You can also go to www.crucial.com and run their scan feature. It's safe and works well.
Note that you should install memory in matched pairs, so if you should buy 2 more 512MB modules, make sure they are the same kind/type. Also realize that should you upgrade to 4GB of RAM, unless you have a 64-bit OS, it may not recognize all 4GB.
As for the drives, any "big box" electronics store will have the drives you need/want. Even Wal-Mart has a decent selection of internal drives. The drives should work with no problem. Gateway and other companies put fancy bezels on the front, but they have buttons and hinged doors that will allow most drives to be used. One thing you need to make sure of is what type of drive you need. That is, what type of controller is used, either IDE or the newer SATA. If you are not sure, comment back and i will try to research it further.
Jan 06, 2009 | Gateway 835GM (835GH) PC Desktop
Boot problem with intel 945g
Try changing the memory Its the memory thats bad or return to the store for warrenty if you have it,
Jan 02, 2008 | Intel Motherboard
Gateway 835GM (835GH) PC Desktop Logo
237 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
