Question about Garden
I have a Kioti CK20 and it will not shut off with the key. I have replaced the ignition switch but this is not the problem. Any suugestions are welcome.
2 Suggested Answers
huffman49
  • 235 Answers
SOURCE: I have a kioti ck20 tractor which will not start.
if it only starts that way then it's the solenoid...good luck
Posted on Apr 12, 2010
2008 gas club car president sometimes acts like ignition is turned off then back on over and over finally after you let off accelerator and try again it might straighten out you never know when
Just key , but if you have a lot of things on key ring, it can ware on ignition switch, try using just the key, if help replace ignition switch and down load key ring. When it is doing this lift up on ignition switch to fix
Oct 08, 2017 | Cars & Trucks
'Key in ignition' chime will not stop when door is open
You have a problem with the switch in the ignition responsible for sensing ignition key, the switch is stock on.
Feb 05, 2016 | 1997 Toyota Camry
How do I troubleshoot a non working fuel gauge on a CK20 Kioti tractor
You can use an ohm meter to check wires and sending unit. DISCONNECT THE BATTERY so you don't put battery power thru your ohm meter. Pull the sending unit out put one lead on the base of the sending unit and the other lead where the wire would hook up then raise and lower the arm and watch your meter to see if it changes to see if sender is working or not.
Mar 09, 2015 | Garden
SAfter shutting off the truck, radio and fan continue to run. Also, went out the other morning and found radio running without keys in the ignition. I tried replacing the relay switch in the fuse box. ...
Check and make sure the ignition switch is not worn out and allowing you to remove the key when the switch is turned backwards in teh accessory position. once the key is removed and the radio is staying on, turn the ignition without the key in it, both directions and see if it shuts off, if it does, menas work cylinder or key.
Nov 26, 2010 | 2003 Ford F150 Regular Cab
1988 f-150 truck won't shut off at the key switch.
if you are looking to just shut the vehicle off pull the crank fuse ..until you can figure out what you did or didn't hook up
Sep 23, 2009 | 1988 Ford F 150
Light on alarm doesnt shut off
the little switch behind your ignition that the key tip moves is broken
replace the ignition switch behind your key opening
Aug 24, 2009 | 1998 Chevrolet S-10 Pickup
Wont shut off!!
faulty ignition relay staying stuck on and not opening when there is no power from the ignition switch
Jul 30, 2017 | 2005 Dodge Neon
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
