Question about Lexmark X1270 All-In-One InkJet Printer
Hi i have a lexmark 1200 series and have just installed a new cartridge but the ink levels are still showing up as low and it is printing nk pages, can someone help me please?
    Sergeant:
    Champion:
  • 259 Answers
Some of the lexarks require genuine cartridges and when they are replace you sometimes have to turn off the printer and then turn back on and if that does not work some of the Lexmarks have a computer help solution centre and you can look at ink levels on screen I have had a Lexmark 1200 and upgraded to the multi function Lexmarks
Posted on Jan 10, 2009
My printer only prints in color I can not get it to print in black even after I change the black cartridge.What is my problem?
Try to open Lexmark Solution Center application on your computer and check if the software recognizes the ink levels of your cartridges. Go to Start menu > Programs > Lexmark 1200 Series folder > Lexmark Solution Center.
You can also use the software to clean the cartridge nozzles for possible dirt and clogs. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print a document again to verify that the problem is fixed.
Oct 28, 2011 | Lexmark X1240 All-In-One InkJet Printer
Printer prints fine so far as text, but a black and white photo has streaks in it. Black Ink level shows it isn't low
Try to clean the printhead nozzles. From the printer operator panel, press the Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. Try to print your photo again to verify that the print quality has improved.
Also, make sure your printer is udpated. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update. The update will help give you a highly reliable print system.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 02, 2011 | Lexmark Prospect Pro205 Wireless...
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
My ink was showing low so i just bought lexmark combi ink from tesco L111 number 34 and 35 and yet printer is still showing ink as empty why is this printer is p4350 model
use the menu on the printer and select the printer options-> ink cartridge-> new ink cartridge and the ink meter should be reset.
Remember that the printer does not actually read the amount of ink in the cartridge it makes predictions about the ink levels based on the number of pages printed on the cartridge.
Jun 30, 2011 | Lexmark P4350 All-In-One InkJet Printer
I have a lexmark 1200 series X1240 printer just installed a new ink cartridge, and the words are triple printing on top of eachother. How may I fix this problem?
remove the cartridge from the clot...clean the metal attachment contacts with a rubber or cry cloth...insert it back in...and align the page once
May 04, 2011 | Lexmark X1240 All-In-One InkJet Printer
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
Low ink level after ink refill prohitting print function
Click on your lexmark maintenance tools and click on install new cartridge. This should fix your problem.
Mar 29, 2008 | Computers & Internet
Lexmark X1270 All-In-One InkJet Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
