Question about Gateway 19" Widescreen Flat Panel TFT LCD HD Monitor
Just doesn't come on any longer
Rarely, when plugged in for the 1st time in a while, I get a brief flash of color bars, then nothing.  most of the time it just does not turn on anymore at all. no light on the power button, nothing.  I haven't tried to replace the power cable because I doubt that is the problem.
  • suukbang Feb 24, 2009
    I shut down a program on my computer and the monitor went off. Afterwards it would show the Gateway logo and then go off again. Now it's off completely....Please help.
    Problem Solver:
  • 9 Answers
This is a very common problem with this monitor. The internal power board has failed. I have repaired hundreds of these. If you are interested in repair, contact me at sure-power@nc.rr.com.
Posted on Sep 17, 2009
Color bars flashing
Try to shutdown your computer and monitor and let them "cool off" for about 20 minutes. If the problem persist the next time you turn it on, the graphic card might be the problem.
If you need any aditional help, let me know.
Jan 04, 2014 | Acer Computers & Internet
I have high voltage at the coil out put....ICM test ok have not checked crank sensor... will not start fuel supply ok
High voltage at the coil means nothing. Hook it to a plug and hook a timing light to that cylinder. If during cranking the timing doesn't flash, you still have ignition problems. Note, it must flash during cranking. Hold trig down.
May 25, 2011 | 1996 Chevrolet Blazer
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
I have a samsung DLP TV, model HLN5065WX. When I plug it in after a few seconds both the lamp, and temp lights flash on the front. It did have just the lamp light flashing and it would have horizontal...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Samsung HLN5065W 50" Rear Projection...
Garmin 1390T Won't turn on - Unless Plugged in car lighter
theb battery is faulty or has not received a proer charge time to allow it to run. If after charging for a longer time 5-6hrs it still plays up return it for a replacement or warranty repair
Jul 19, 2009 | Garmin nuvi 200W GPS Receiver
When on button pushed, brief lighting of hard drive light won't
Remove the battery, hard drive and memory chips then put the back nice and firmly. It often is the solution for such a problem. Otherwise the hard drive has bad sectors and cannot always read the operating system files to boot up.
Jul 06, 2009 | IBM ThinkPad T22 2647 Notebook
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Every time i plug my printer in the on light flashes and nothing else happins
please check the cartridges as the on light blinks because any of the faulty cartridges is not getting detected in the printer.so remove the cartridges and clean the contacts in both printer and cartridges.
also mention your printer model number.for more brief help.and also try removing all the pc wiring connections from the back of the printer and then check.ON/OFF 3-4 times and it normally gets reset.
Oct 05, 2008 | HP Office Equipment & Supplies
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Open Questions:
Gateway 19" Widescreen Flat Panel TFT LCD HD Monitor Logo
134 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
