Question about tracfone.com
How do i get my voice mail ? - tracfone.com
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
Mismatch of application settings no voice mail. how to fix
some phones have virtual voice mail...which means you must syc it with the service voice mail ... if voice mail is pass word protected ...you must program the voice mail password and information into the virtual voice mail or it will not retrieve messages or give you notification of incoming voice mail.. The directions they give you for this is really asinine and hard to understand. Call your service provider they will be able to help you.
Mar 11, 2015 | LG G2 Black Smartphone - Verizon Wireless...
I don"t have voice mail.
Pls fist put you sim in deffrent mobile and call to you number and you call is going to voice mail so going to voicemail so ok Thats you mobile problem but if you no going voice mail so active you voice mail device call to service proivedar of you network ...ok
Mar 05, 2011 | Motorola Mobility W385 Cellular Phone
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
How do i setup my N73 voicemail
sir the voice mail box is a network service to which you may need to subscribe .for more information ,contact your service provider .to call your voice mail box ,press and hold 1 .........to edit your voice mail box number ,select menu >messaging >voice messages >voice mail box select the following settings to setup the voice mail
Nov 23, 2010 | Nokia N73 Cellular Phone
How do I access my voice mail?
put your voice mail number in voice mail settings or you can dial directly your vc number to listen your voice mails,if you dont know your voice mail number then ask your network operator for number
Aug 29, 2010 | Cell Phones
Voice mail recording for my new panasonic digital phone
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Jan 13, 2018 | Panasonic KX-TG4322B Twin Cordless Phone
Voicemail
Press and hold the "Mute" or "Clear" button until the handset beeps to clear the New Voice Mail allert.
Jul 04, 2008 | Panasonic KX-TG1033S Cordless Phone
Voice mail notification to cell phone
This is a phone system phone. What you are looking for would be a feature of your voice mail that is connected to the phone system. "Handsfree Speakerphone- 3-Line Back Lit display and 24-Line Keys. Compatible with KXTDA200 and KXTDA100 Systems. " Sounds like you either have a KX-TDA200 or KX-TDA100 phone system. Usually voice mail is an optional feature and has a separate part number. You could also have voice mail service through your phone service provider (like Verizon) Do you have any user guides for your voice mail or one for your phone that covers voice mail features? If not, the first step is to find out for sure what you have for a voice mail. If you have a working message waiting light on the phone it would be an in-house voice mail connected to the system.
Sep 13, 2007 | Panasonic KX-T7633 Corded Phone
tracfone.com Logo
55 people viewed this question
Top tracfone.com Computers & Internet Experts
Andrew Taylor
Andrew Taylor
richie46
robert
Are you a tracfone.com Computer and Internet Expert? Answer questions, earn points and help others
