Question about Sony VAIO AW Series VGN-AW190JAH NoteBook
VGN-AW190JAH CPU upgrade
  • Gary Sherrick Nov 28, 2012
    I want to upgrade the CPU, the memory and add a second hard drive, anyone have any suggestions
  • Sony Master
  • 7,627 Answers
Sony vgn-z520
Usually, it is not possible to upgrade the cpu on a laptop. In rare cases where it is possible the upgrade usually costs nearly as much as a new laptop.
However, you can significantly upgrade the laptop's performance by adding more memory and by replacing the old slow hard drive.
Your Sony VGN-Z250 is usually supplied with 3GB of RAM memory. You can replace the existing memory modules with a new kit consisting of 2 x 2GB modules (total 4GB). The type of memory you need is "SO-DIMM" (meaning laptop size) DDR3 - 1066MHz (you may use 1333MHz memory but it will only run at 1066MHz speed). I would suggest either G-Skill or Crucial brand memory. And you can replace the hard drive with an SSD. You'll be amazed at the boost this provides, seriously. I would suggest either Samsung 840 EVO or Sandisk Ultra for an SSD. Both offer super-fast performance compared to your old spinning hard drive, and both have very low power consumption so they run cool and give your laptop a few extra minutes of battery power. You can clone/copy your existing Windows setup onto the SSD using free Macrium Reflect software or free software from the SSD maker's website. Or, you can do a fresh install of Windows.
Mar 27, 2013 | Sony VGN-Z520N/B PC Notebook
Upgrade sony vaio vgn-fj270
I need motion eye driver for a vaio vgn fj1s. any one can help me? thanks!
Jul 28, 2012 | Sony VAIO VGN-FJ270/B Notebook
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
Would like to upgrade cpu on my sony vaio vgn-fz285u notebook
The choices are limited, as the series of processors that can be inserted in a mother board is limited. The motherboard will have a socket specification that determines the CPU series that can be used.
Sep 27, 2009 | Sony Computers & Internet
Upgrade the hard disk & cpu of my sony vaio vgn-z540
there are several panals on the the back of the laptop the harddisk is under one of them not to sure about the cpu tho
Apr 06, 2009 | Computers & Internet
MEMORY UPGRADE
from the white page I found:
"The 17-inch widescreen Sony Vaio VGN-AR230G, the first entertainment Sony’s AR notebook with Core 2 Duo Mobile (Merom) processor, is now available at SonyStyle.com. The Vaio VGN-AR230G comes with a T5600 (1.83GHz, 2MB L2 cache) CPU, an 1GB DDR2 SDRAM (expandable to maximal 2GB), an 200GB 4200rpm SATA hard drive and a dual layer DVD burner ."
There u are, only 2GB.
/Teis
Dec 29, 2008 | Sony VAIO VGN-AR230G Notebook
Sony Vaio VGN CR-220E
Haha!
I had such dreams too with one of my old Vaio. I really wanted to upgrade the processor and graphic chipset. Turns out that the latter is impossible (it was soldered to the motherboard - it wasn't a graphics card, just an all-in-one chip), as for the processor I was able to take it out but I ran into several problems:
1) vaio added electronic components to the motherboard that made higher CPU speeds unachievable even if the motherboard's cipset (VIA) was able to do that.
2) the cpu maker (AMD in my case) kept telling me that their mobile cpu were custom designed for that specific laptop, so new cpu would be incompatible. Also mobile CPUs are, apparently, only sold to laptop makers, unlike OEMs... (eBay but at ur own risk!).
3) When buying a new CPU, u need to check factors such as the number of pins (mobile cpu are much smaller), voltage, current, wattage and heat dissipation (very important, ur current heat sink was designed for ur current cpu).
But maybe things have changed now. In my case, I could only upgrade the RAM and the hard-drive to larger and faster versions, and the difference was quite significant difference. Faster booting and better internet experience.
May 03, 2008 | Sony VAIO VGN-220E/B Notebook
UPGRADING PROCESOR
Make sure your BIOS can handle an upgraded CPU. I would go into bios, check the "default" or "fail safe" boot option and then power down. Lift keyboard or access your CPU and change out. Remember to touch something metallic before you operate so you discharge any static electricity (killed a CPU and a video card by not doing this ONCE) Boot up and notice any BIOS messages, may want to start in safe mode just to get a basic working config going, then power down, access BIOS and start getting it back to your best config, maybe stepping one item at a time, rebooting and continuing until you get a stable platform.
Jan 22, 2008 | Sony VGN-S150 MBX109 (M9_32 (A1072469A) PC...
Sony VGN-460 Memory & CPU Upgrade? Noisy Fan How do I replace it?
The Crucial website suggests you can put 1GB in each slot. http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-S460%20Series Sony might know which CPUs will work with this. Hopefully any Pentium-M with 533 FSB.
Sep 21, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO AW Series VGN-AW190JAH NoteBook Logo
52 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
