Question about Gateway Computers & Internet
Cpu fan running at full speed
It started out of the blue yesterday, prior to that, it ran at slow/low speed. The fan goes to high speed on start up from cold, does not appear processor load related. CPU (4) temps range from low of 26C to high of 41C. Fan is constantly runnng around 4500 rpm - quite noisy.
  • Gateway Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
desktop or laptop computer fail to boot for a variety of reasons, but a fast, loud fan noise signifies that the system is suffering from overheating.
The problem, and the steps for troubleshooting it, is not unique to the Gateway Desktops.
When the internal temperature of the computer reaches too high a level, the system will shut down automatically to allow the heat to dissipate.
If you attempt to power up too soon, the machine will not boot properly.
To boot, you will need to correct the cause of the overheating, and keep the machine cool.
Blocked Vents
Although different in size, both desktop and laptop computers have air vents to help the fans keep air circulating around the hot internal components.
If these vents become blocked, by pushing a desktop too near a wall or using the laptop on a soft surface, the air supply your internal fans need to cool the system is cut off.
This blockage also traps the heat inside, allowing it to build to dangerous levels.
Keep the air vents on your computer free and clear to allow proper airflow.
Dirty Computer
Airborne particles, such as dust, lint and hair, can gather on the air vents and internal components over the course of time.
This accumulation of dirt not only provides a sort of "insulation" to the electronic components, preventing the heat they generate from dissipating normally, but it also clogs the fan and heat sink to prevent proper function.
Use canned air and damp, soft cloths to thoroughly remove any built-up debris from inside your computer.
Dried Thermal Paste
The heat sink sits atop the CPU chip to help dissipate the heat the component produces. Thermal paste is layered between the CPU and the heat sink to help draw the heat away from the chip for cooling.
Over time, the cooling properties of this paste decreases, and the substance becomes dry and flaky.
You can replace this paste to renew its cooling assistance by removing the old paste remnants with rubbing alcohol and adding a new layer.
Thermal paste is also known as thermal compound or thermal grease, and is available at most electronics stores.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Hot Environment
When examining overheating causes, don't overlook the environment you use your computer in.
External heat sources, such as fireplaces or even rays of direct sunlight, can cause the internal temperatures of your computer to rise.
This causes your internal fan to run harder in an attempt to dissipate the combined heat before temperatures rise too high.
Move your computer away from external heat sources to encourage more effective cooling.
Hope this helps.
Posted on Nov 28, 2012
Noggin
  • 944 Answers
SOURCE: uncontrolled CPU Cooling Fan Speed
Here is the link for all the various support manuals, software and instructions for your PC if you need them; http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=179911&taskId=101&prodTypeId=12454&prodSeriesId=316713 CPU fans should be plugged into the CPU fan power socket on the motherboard, in order to receive variable speed control instructions. If the fan has been incorrectly connected to a different motherboard fan socket, or directly to the power supply then it will run at a constant speed. If it is correctly plugged in to the correct socket, then the hardware management software (there are many possible options here - please post back with which management software you are using and I can give more specific instructions) that comes with the PC should allow you to change the settings - you can change the temperature range at which the cpu fan will go into higher speed mode - it sounds like you may have this set too high You should also be able to control the fans from the BIOS set-up menu - this should be accessible when you boot up. usually it will be by pressing F8, but all systems are set up slightly differently. watch the screen as you boot up and it should give instructions for this. Hope this helps, please give more details of how your machine is set up if you need more specific help :)
Posted on Sep 07, 2007
TeK Micro
  • 62 Answers
SOURCE: Desktop CPU Fan Problem
My first check would be to see if the manufactuer has a BIOS update for the ma inboard that resolves that problem.
If they don't have one available on their website I would contact their technical support because it may be a known issue that they are currently working to correct.
At least knowing you'll know that a fix is only a few months away.
If the manufacturer claims that your problem can't be verified you may have a faulty thermal control unit on the mainboard.
Let me know what you find out.
Posted on Jan 08, 2008
  • 16 Answers
SOURCE: CPU fan races
thanks bigunit12 - as I suspected, no real concern
expect the noise is a pain.
I do think the HS might be marginal and so I shall replace sometime with a higher capacity model, also maybe increase fan flow capacity and add a case hot air extractor fan.
Just to make sure
hotratchet
  • 952 Answers
SOURCE: CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Posted on Jun 20, 2009
pra0099
  • 153 Answers
SOURCE: my sony vgc-rb40 will not boot bios with cpu fan connected
mostly all fans are 12V DC try connecting all the fans directly to SMPS of the system i.e the red and the black wire
Posted on Sep 18, 2009
Blower just started staying on - furnace has been turned of for 6 months
This is a diagram of a blower relay and a fan motor, the normally closed fan relay switch goes to the low speed which is the Heat speed, the low speed is controllled by a temperature delay depicted in the low speed circuit.
The normally open fan relay switch goes to the high speed, which is the AC modes speed , also if you run the fan continuously via the fan switch on the thermostat this is also to high speed.
I suspect the temperature delay's on setting is being reached thus cycling the low speed of the fan.
Nov 08, 2015 | Heating & Cooling
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
I have dell optiplex gx280 computer.i am facing problem of CPU high fan speed when i turn on the PC.it goes to full noise like a jet fighter and nothing get appeared on the screen and fan continuously gone...
dells usually go full blast on power up then slow down to normal,sounds like fan is not responding to slow down signal i would try replacing fan, its got to be a dell fan
Jan 08, 2011 | Dell Optiplex GX280 (99301) Motherboard
PC runs great until you power completely off. The it will take several tries of power on attempts. It will not start with the CPU fan coming on high speed. Must keep trying until low speed is heard. I...
Sounds like a problem with the power supply based on what you've written. Could be motherboard too, but Power Supply is usually the culprit.
I'd swap it out to test ;)
Jan 01, 2011 | HP Pavilion a450n PC Desktop
My unit has been running great up till now. Just
Check compressor for high current consumption.Check capacitors. Check fan speed.
If fan speed is low compressor will over heat and trip safety circuit in the compressor. If there are independent fans check both of them.
May 26, 2010 | Mitsubishi MS-A12WA Air Conditioner
Toshiba 2435 s255 notebook shutsdown and fan runs on high speed
Overheating problem is caused by faulty fan and or the fan and heat-sink assembly is clogged with dust.
When the CPU overheats, it goes into thermal shutdown and won't boot up again until the CPU has cooled down. If this problem is not fixed, eventually the CPU will fail completely. The fan must spin freely, if not replace the faulty fan.
Check the fan and heat-sink and loosen and vacuum/remove the dust from the fan and heat-sink assembly. Depending upon the model of your Toshiba, the fan can be accessed from the bottom of the laptop or you may need to remove the keyboard to get at the fan and heat-sink.
Jan 22, 2010 | Toshiba Satellite 2435-S255 Notebook
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
2 ghz processor running at 220 mhz
Have you tried right clicking on the desktop (opening Display Properties), clicking on Screen Saver tab, Clicking the Power button, and setting the power schemes to Home/Office Desk? If its set on laptop it will reduce the processor speed when running on battery. I have noticed that even with it plugged in that some times it will run at half processor speed. Try that out.
Have a great day,
Armymason
Mar 02, 2009 | Dell Inspiron 9300 PC Notebook
CPU fan races
turn up the task manager to monitor the cpu load. use ctrl shift esc to bring it up. now open up an application. see as the cpu meter goes from low to full green (high).. then check if the fan also speeds up. i guess you have a cmos setup on the motherboard that monitors cpu load and speeds up the fan.
as for the usb -speaker, please explain further..
May 20, 2008 | Car Audio & Video
Computers & Internet Logo
134 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
